| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
| Hello all,1st thanks to Jung for the help on my Star problem.Today I have replaced an encoder on a citizen E32 for X1 axis.I've been told to do a gridshift for the new encoder. Is that necessary,can't it pick up from the zero return switch?If so I have a procedure but I'm not sure how to do it.TIA |
| Replacing the encoder changes the position of the encoder marker pulse, which the reference is taken from, the switch only tells the control to look for the marker. If you don't care about the new zero position being different, there is often no need to change the grid shift, which on most controls is a parameter value in encoder step counts. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| If you do any drilling or use the Tool Presetter, you'll be much happier having done the Grid Shift. It's pretty straightforward. Good Luck! |
| repair or replace? | hollyfeneht | Benchtop Machines | 21 | 06-04-2007 06:27 PM |
| Upgrade or Replace? | FoamGuy | Fadal | 9 | 06-21-2006 02:15 PM |
| Replace gibs? | cncuser1 | Benchtop Machines | 1 | 01-04-2006 10:58 PM |
| How to tell if my motor is Pulse encoder or quadrature encoder? | Darc | Servo Motors and Drives | 0 | 07-22-2005 04:51 AM |
| replace old control | dmerrll | Gecko Drives | 1 | 12-18-2003 11:31 AM |
