| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
I have a long term project I am quoting on. It would be turning a cone point on .003 diameter wire swaging flats further in and then cutting off at .500 long. Is a screw machine the right machine for the job? If so would one make be better suited? If not a screw machine then what would do three operations like that? Thank You |
something like this would be ideal i bet: http://www.marucit.com/products/R04.html I've never even thought about cutting parts that tiny, so i cant offer a whole lot of advice. |
| What type of volume/year is the production requirements? Sound pretty "unmakable" on a swiss to me...at least economically. The problem with the swiss will be the distance between the Collet and Guidebushing. You are "pushing" the material through the guidebushing and at .003 wire, this will be a tremendous up hill fight. Sounds like you need a rotary transfer or trunnion machine. Maybe even some type of wire or spring forming machine could do this. That being said, if your volume is low and you made it out of larger material, the above link to MCC's "R" would be a good bet. Good luck with your quote. |
| Wow, that is an almost unimaginable task ![]() First off, how much damage is 'swaging' going to impart to the shape of this wire? It's going to be nowhere near as round as it began, so will it have to be rounded again? As for the cone shape, I think it could be lapped on, rather than turned on with a cutting tool.
| Shaft Diameter, LeadScrew Diameter, Motor Torque? | cnc-newb | DIY-CNC Router Table Machines | 8 | 12-24-2007 03:51 PM |
| Turning Brass | BeerFizz | Mini Lathe | 13 | 08-24-2007 06:24 AM |
| turning motor shaft to smaller diameter | smoker | General Material Machining Solutions | 5 | 03-08-2007 10:56 PM |
| Turning smaller diameter delrin? | conceptmachinin | General Material Machining Solutions | 29 | 03-08-2007 03:02 PM |
| Turning brass | kdoney | Mechanical Calculations/Engineering Design | 2 | 04-29-2006 07:48 PM |
