| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hello everyone, I didn't know where else to go so I figured you swiss wizards might be able to help. Here's the situation. I am running a job of 17-4 s/s threaded studs. 5000pcs. They are 1" long, and have a 4mm x 0.7 thread. They are slotted at one end. I am using a Geometric 9/16 D self opening head. This is being done on a turret lathe. The chasers are new Quality Chasers, 45 deg. chamfer 15 deg. hook. I ran 1500pcs. for the first release with one set of chasers no problem. For the second release, I switched to a new set of chasers and started having immediate taper problems. Over the length I was getting a .006" taper, smaller at the beginning of the thread where the die head started. No idea what is going on. Contacted Quality and they had me send them the chasers. No problem with them. They did change the chamfer to 33 degrees, and honed the hook. Put them in and they worked. Ran about 350pcs. and am starting to have this problem again. Taper is less, about .002-.003 but I still don't know why this is occuring. Any ideas? Thank you in advance for any help. Regards, Philip Confalone PC Machine Works
__________________ Philip Confalone Machining Concepts |
| You ran the first 1,500, did you break off and reset up? It certainly sounds like setup issue but take a look at ... is the Pocket line-up (indicator) is the Pocket straight (indicator/ z travel) is the Geo head on center (some of them have their own adjustment) does the head open/close "freely" are all the chasers converging on the same center is the turret stop set propperly (if mechanical) is the z feed propper(if CNC) is the material from a different lot has the blank changed or is the blank tapered does the major and minor taper the same amount These are jus a few. Good Luck |
| No, setup stayed the same. Just changed out chasers. Like I said, the first 350pcs. ran fine. Why would it suddenly change? I was thinking the clamping pressure on the collet might be doing it, but then again that really doesn't make any sense. If I had any hair I'd be pulling it out! LOL Regards, Phil
| What's the taper on this? | la_coterie | Commercial CNC Wood Routers | 4 | 02-20-2010 03:15 PM |
| Taper 40 N.S. | professor | Industrial Hobbies (Support forum) | 2 | 01-13-2007 08:14 PM |
| Taper Head Shoulder Torx Cap Screw | Smackre | Wood Working Tooling | 0 | 11-20-2006 01:18 PM |
| BT to CAT Taper | machinistJ | Fadal | 2 | 02-14-2006 03:36 PM |
| R8 taper | lt paul | General Metal Working Machines | 2 | 06-10-2004 11:31 AM |
