Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 05-21-2008, 02:57 PM
tech5028 is on a distinguished road
Unhappy Star VNC 20 turret problems
Hello all.I'm working on a Star VNC 20 and have been trying to get the #1 turret to clamp.We replaced the encoder for #1 and that didn't help.I took the encoder belt off previuosly before replcing the encoder and since then it hasn't been clamping at all.Mechanically moved the solenoid and it will clamp.Original problem was would clamp at times especially if you rapped the tool after it stopped in position.Please help!Fanuc controls
Old 06-16-2008, 11:07 AM
Jung is on a distinguished road
Take out the belt, MDI a T command of this turret. Desired tool will come but turret do not clamp. Turn encoder slowly until turret clamp. Mark this position and put the belt back.
TL-1 Turret problems RDemets Haas Mills 10 04-28-2008 03:46 PM
hass tool turret alignment problems! Doug D Haas Lathes 12 10-22-2007 09:04 PM
Mazak Nexus 640 Tool Turret problems chattwo Mazak, Mitsubishi, Mazatrol 0 09-21-2007 12:27 PM
Star TZ250 Dolphin CADCAM 2 08-27-2007 08:09 AM
Turret alignment problems coquina Haas Mills 15 07-17-2007 07:53 PM
