Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 05-20-2008, 12:17 PM
settingbur is on a distinguished road
cutting parts off short
I have a F 20 citizen and for some reason it is cutting off parts short by as much as 1/2", tried several different programs and same result. Anyone have any ideas what can be the problem. Thanks. Cutting M2.
Old 05-22-2008, 07:37 AM
ProProcess is on a distinguished road
material getting stuck in GB
incorrect cut-off shift
material slipping in Main collet while turning,drilling ect
these are just a few...
good luck
Old 05-22-2008, 07:29 PM
PoiToi is on a distinguished road
^^ x2.
where is the short dimension on the part? if you look closely and find out where the problem is occuring, then you can narrow down the root causes.
Example, if a drilled hole on the end is short too, then the material is probably pushing back in the main chuck. OR if the front of the part is missing, clean out your main chuck real well, or put a G04 at the end the program on the line after where the chuck opens(M7 on my citizens) and the next line. or if you can, add a little more weight to your bar pusher. We have crappy gravity-feed pushers, so its easy to add a little more weight to the rope. I'm always maeein with those things >_<
explain your problem in a littl emore detail, i've found that always helps on this site
Old 08-08-2008, 03:15 PM
KentL is on a distinguished road
9 times out of 10 it's the bar feed.
Old 08-16-2008, 11:00 PM
So CA Machinist is on a distinguished road
When I ran our swiss lathe, most of the time the material (bar) was bent in a spot..once it got past this point...it was all good.
Check to see how tight your main spindle is clamped onto the bar?
With the chuck open..see how easy the material slides thru by hand.
It could be all in the set-up. Maybe your guide bushing is too tight?
Look at each variable..you will find the problem.
When in doubt..switch out the guide bushings and collets and clean everything really good.
Hope this helps out.
Ron - Covina, CA
Cutting First Parts Big John T CNC Plasma and Waterjet Machines 13 05-14-2008 04:27 PM
Holding Parts Down While Cutting Oldbill DIY-CNC Router Table Machines 11 01-11-2008 04:12 AM
Im cutting on a slant, and my bits are to short replicapro Mach Mill 3 07-19-2006 01:18 PM
Need help cutting 2.5/3d parts. bdesh123 G-Code Programing 5 04-17-2005 11:18 AM
info on cutting rc parts landart DIY-CNC Router Table Machines 0 01-18-2004 07:29 AM
