Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 05-13-2008, 01:31 PM
PoiToi is on a distinguished road
Single pointing 304 SS.... destroying tools!!
hey all, i was wondering if anyone could help me out.
i have to single point a #6-32 thread on the OD of a 304 ss part, and its giving me TONS of grief. the insert nose is chipping out on the first part, and it seems to be forming the material, making the thread major diameter way oversize(.010)
I've tried a lot of different speeds and numbers of passes, from 15 passes at 1600 RPM to 6 or 8 passes at 2400 RPM, and there is no discernable difference... i;ve also tried changing the relief angle on my thread tool.
any help would be appreciated!!
thanks!
Old 05-14-2008, 06:02 AM
ProProcess is on a distinguished road
Try using "Compound Infeed" G76
Old 05-14-2008, 06:41 AM
jalessi's Avatar
jalessi is on a distinguished road
G76
G76
G76- Canned threading cycle
G76 P010010 Q0020 R0005 (first G76 sets parameters for threading)
G76 X Z P Q F R (cuts the thread)
The first G76 isn't needed but is recommended.
- G76 P Q R
P010010 sets 3 things
- first 2 digits is the amount of finish passes - 01
- second 2 digits is % of the lead or pullout exiting the thread- 00
00 = almost no angle at pullout and 99 = 9.9 leads away start out
- third 2 digits are the angle of infeed - 10
0-99 are usable
Q0020 sets the minimum cut amount during threading .002 but no decimal
(Q00200 for sub inch)
R0005 sets the cut amount of the last pass .0005 but no decimal
(R00050 for sub inch)
The second G76 cuts the thread.
-G76 X.1876 Z.3 P0302 Q0010 F.05 (R-.002) FOR 1/4-20
X.1876 =Minor Dia. of thread
Z.3 or (W) =The ending Z of the thread
P0302 =Height of thread in radius (Maj-Min)/2 (.0302)
(P03020 for sub inch)
Q0100 =Amount of the first cut. All the rest of the cuts are calculated.
(.01)
(Q01000 for sub inch)
F.05 =Feed-rate 20 TPI 1/20=.05
R = R is optional for tapered threading. R is the amount of
difference in X from start to finish in Z. When cutting threads
moving Z and X in a positive direction R is a negative value.
Old 05-14-2008, 08:47 PM
PixMan is on a distinguished road
First, what machine and control are you using? Only a very late-model control with fast processing time would be able to thread at those spindle speeds reliably. On most Fanuc 18i-TB, 16i-TB and 21T controls, speeds of about 2000 are where you should max out, though some Star and Maier machines with 1320ipm (33m/min) rapid rates can go as high as 2500 in G76 cycles without too much trouble as long as your approach and retract amounts aren't excessive.
DO use a full-form 32p threading insert WITH the proper angled anvil under it for that small diameter. I recommend Valenite threading tools for this application. Depending upon what shank size your lathe takes, I can recommend the right holder, but for the threading insert and anvil you will want:
Insert 16ER32UN, Grade VC929 EDP No. 01942
Anvil CAE 16 3.5P EDP No. 08264
In that G76 cycle, use a different value for the first "P" parameter, to match the thread included angle and give the tool a compound angle infeed. It should read "P010060", or better yet (to give it a clean-up chip on the backside flank and plently of "free spring passes") use: "P040059"
hth
Old 05-19-2008, 06:14 PM
bbox is on a distinguished road
304 forms a work hardened skin as you cut your threads. You must get under that skin for a clean cut on the next pass. Try to make your cuts .005" deep at least, deeper if possible.
Bill Box
Old 05-28-2008, 07:31 AM
JMS4287 is on a distinguished road
This might sound a little too obvious...but you might want to re-check the center height of the tool....with chipping inserts and the major dia being oversized, like the material is pushing away, that would be where I would start looking....especially with a small thread...
Old 06-13-2008, 10:56 PM
SWISS20 is on a distinguished road
can you display the program from before you start turning the OD to the end of the threading cycle.
Bring your own tools or does your company supply tools? ZipSnipe CNCzone Club House 10 02-04-2011 08:06 PM
Lathe question: Thread milling vs. single pointing.... PoiToi General Metal Working Machines 0 02-21-2008 08:24 PM
Single to Three Phase Help, Please elalto General Metal Working Machines 20 01-04-2006 06:01 AM
110 single phase to 220 single phase. Nono General Electronics Discussion 36 06-05-2005 08:51 PM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 09:15 AM
