Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 05-08-2008, 02:06 PM
PoiToi is on a distinguished road
8 mm or 3/8" shank straddle knurls??
hey all, I was wondering if anyone knew where to get a straddle style holder for my swiss machine, but in an 8mm shank. everything i've found is 12 or above. I talked to genevieve swiss to see if it'd be possible to grind down one of their 1/2" holders, but it's not possible.
anyone know of anywhere else??
thanks!!
Old 05-09-2008, 06:10 AM
ProProcess is on a distinguished road
You could...
If this is for a gang tools position, you could drill and tap a 12MM holder and bolt an 8MM adapter ... that you would have to make.
If this is a turret position, you could mill out the holder pocket to accept the 12MM shank.
Good luck!
Old 05-09-2008, 06:10 PM
beege's Avatar
beege is on a distinguished road
Call AccuTrak. They should be able to help you, adapt a holder for your needs.
1/2 Shank End Mill duhtrev CNC Tooling 6 08-04-2008 04:27 PM
Drawing a threaded shank wdp67 BobCad-Cam 5 10-17-2007 09:16 PM
Tapmatic shank change ozzie34231 Manual Machining Tooling 3 04-25-2007 01:52 PM
Tapered shank drills sharpened Rockwell Hobby Discussion 0 04-18-2007 09:44 PM
Flycutter shank style thackman Benchtop Machines 1 03-07-2007 12:41 AM
