Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 03-03-2008, 01:22 AM
EvansMachine is on a distinguished road
Suggestion for swiss cutting oils
Hello,
I have a Tornos ENC 264. I need to flush the system and buy new cutting oil for it. Does anyone here have a suggestion or caution on what to buy or what not to buy. This is the first time I have had to buy coolant for it and am unsure what to get. Thanks for the input.
Old 03-03-2008, 08:58 AM
Swissman is on a distinguished road
coolant
I have 7 swiss machines, and i highly reccomend Blaser Swisslube Vascomill 22. It is a vegitable based oil coolant. It works great for cutting most materials and has a high flash point. if you get into cutting more higher end materials, eg. cobalt chrome, inconel, etc. use the blaser HD. it has a chlorine additive to keep chips from sticking to the cutting surface.
Happy machining
Old 03-03-2008, 10:02 AM
cncswiss1's Avatar
cncswiss1 is on a distinguished road
we run hangsterfers hardcut NG in our swiss, also an ester based oil (synthetic derived from vegatable). nice high flash point, and some parrafinated chlorine. 7 weight so it pumps nice. I have tested motorex orthocut, and it's nice as well.
Old 03-03-2008, 10:34 AM
kccrusher is on a distinguished road
Martin Chemical's Remcool-V80; it's veg based, too.
Old 03-03-2008, 02:11 PM
SWISS-TECH is on a distinguished road
We are running Motorex Ortho NF-X 22.
Old 03-03-2008, 06:51 PM
cogsman1 is on a distinguished road
I would second thet Vascomil22 but also when you need thinner for small thru coolant tools there is vascomil10. This also handles the high pressure pumps very well. Recovers quickly so you don't need to shut down to help in the recovery.
Hangsterfer's is also very good but I just don't like the odor. Has trouble with the hi-psi pumps though.
Old 03-03-2008, 10:12 PM
cincron is on a distinguished road
I've used swiss silver HP for years... works good... keeps things clean...
~Tony~
{Process Engineer, Lead Machinist, Supervisor, Computer Enthusiast, Linux & M$ User}
Old 03-04-2008, 12:57 PM
JMS4287 is on a distinguished road
We Run Blaser Vascomill 22 as well
heres a Link
http://www.blaser.com/index.cfm?type...id=379&land=us
Old 03-21-2008, 03:46 AM
PHD PHD is offline
PHD is on a distinguished road
We used to use Hangsterfers at Hewlett Packard. Not stinky like some other types. Also used Cut Max to prevent seizures of the stock in the machines that used dead bushings.
Old 03-29-2008, 09:47 AM
machinemike is on a distinguished road
I use the Hangstefers vegetable oil on my TB Deco. I do a lot of deep hole drilling in titanium and it works great. Incredible tool life with it as well.
  #11   Ban this user!
Old 05-01-2008, 08:53 PM
SWISS20 is on a distinguished road
We are using the Hangstefers Hard Cut 525 Light. We use our high pressor systems alot and run our machines 20 hours a day. the lighter oil works great with the high pressor systems and cleans off parts better than others. We run more steel than anything, but run alot of brass and aluminum as well, Works Great!
  #12   Ban this user!
Old 05-15-2008, 07:46 AM
rosko is on a distinguished road
I also use Blaser Swisslube Vascomill 22 in my shop.
Best swiss tooling?? PoiToi CNC Swiss Screw Machines 8 01-30-2008 11:18 AM
Need info on Cutting oils widgitmaster General Metal Working Machines 16 04-03-2007 03:14 PM
Help any suggestion spindle brand/model for Alumn/wood 3D cutting Milling ? Calico General Metal Working Machines 0 08-30-2006 05:15 AM
oils for Cincom F12 emilm General Metal Working Machines 1 09-27-2005 06:40 PM
