Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 02-13-2008, 07:00 PM
PoiToi is on a distinguished road
Question Guide bushing scratching on 303....
I'm sure someone has had the same problems as me, so i was hoping someone could give me some insight....
We are making some parts out of ground bar stock that the customer supplied, and it's already ground to the size they want on the OD. However, my citizen b12 keeps scratching up their stock (they want to keep the 16 finish....). we got a special guide bushing that supposedly is soft enough to keep from scratching up the 303, but i haven't noticed an appreciable difference. I've loosened up the GB enough that the stock slides out during re-chucking and makes the part too long, and there are still scratches :angry:
Is there any tricks anyone uses to keep the OD looking nice and pretty?? I thought about making my own guide bushing out of brass or bronze, but that's a bit of a project, and i'm busy enough. I know i could always get stock a bit bigger and just turn it down (I'd RATHER do it this way, actually), but is there any way to use the customer's material??
thanks!!
Old 02-14-2008, 12:02 AM
yoopertool is on a distinguished road
PoiToi,
I sometimes have to use stock finish on parts where scratches are not acceptable. What I do on occasion is to take a few pieces of the material being turned and heat treat them as hard as possible (if you have heat treating capabilities). I then put the bushing in the machine and leave it just slightly loose on the material, so that the bar will slide through fairly easily. I then take my hardened pieces and apply some VERY fine lapping compound to them. I proceed to push a piece with the compound through the bushing for a while. I then tighten the bushing up to almost where you would run it at during operation and run another compound coated piece through it. What this will do is ensure that your bushing is truly sized to your material. This usually takes care of all my bushing issues. Good luck!
Old 02-14-2008, 11:49 AM
JMS4287 is on a distinguished road
We also Run into this reguarly ..Lapping the Bushing as Yoopertool said, will ussually take care of it...Breaking the Slot edges on th Bushing Before Lapping can help as well..As small diamond file usually works if the bushing is big enough..
Old 02-16-2008, 11:16 PM
cncswiss1's Avatar
cncswiss1 is on a distinguished road
get a non slotted gb, non adjustable, but much less scratching.. also if you are picking this off the sub may be your problem, or the main for that matter
Old 02-28-2009, 02:20 AM
chetan is on a distinguished road
thanks!!
Hi poi toi
I think you should use habegger guide bush. this are costly but this the only solution for your problem.
Pneuamtic Guide Bushing Assm on Citizen's JMS4287 General Metal Working Machines 1 08-29-2007 08:45 AM
Hole for press fit bushing SurfRunner General Metalwork Discussion 6 08-02-2006 07:20 AM
Is it possible to turn closed round bushing into C shaped bushing ? vroemm Linear and Rotary Motion 7 06-27-2006 06:04 PM
STAR 067-30 bushing, how can i see if it is worn out ? vroemm Linear and Rotary Motion 0 06-26-2006 10:07 AM
Bronze bushing idea Zumba Linear and Rotary Motion 8 04-14-2006 06:18 AM
