| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
#13
| I am still confused why you would need a y-axis and why the helical is a problem. When you rotate c-axis that is just like moving x and y in a mill. When you are thread milling in a mill your tool is not positioned on an angle.I have thread milled several parts in a star machine using c-axis and the parts looked fine and checked fine. |
#15
__________________ The best way to learn is trial error. |
#17
| I know that G12.1 will convert C to Y axis. But will it work on a off center hole? I know the turret will over travel. But if it didnt over travel will it still work. Having X,C, and Z working together on a offset hole? G12.1 works good on X and C "Y" but how about all 3 axis. |
#19
| Yes, I have done it, exactly what you're referring to... thread milling internal thread off-center using the turret on the sub of an M-32 without a true Y-axis. And here's the helpful part... It was five years ago, and I don't have a copy of the program. (previous employer) 22-13-5 stainless was hard on taps, it milled much easier. And we were making small pressure fittings, so threads without flats/scallops was essential. iirc, it was pretty straightforward... rapid to cl of hole lock spindle in milling mode rapid to (depth - 1 thread) helix move to majorØ over a Z length of 1/2 thread lead (Important, to keep the thread crest from getting truncated) helix move to depth helix move out to cl of hole. That being said, your code looks very strange to me: M_V$WSP$13 TRANS_OFF If this is what is posted, does it actually work? My apologies for not having the code handy... it was literally 5 years ago, and I haven't laid hands on a CinCom program for at least three. But half the battle is knowing it can be accomplished, yes? I will look through my notes from back then and see if I can find something a little more helpful... |
#20
| That code will look strange to you ghyman cause its not for a citizen, its for a DMG Gildemeister twin 65 machine. My friend is trying to do it on thier. I just figure if the citizen can do it that machine should be able to do it. I want to thank everybody for their input. |
#21
Been There And seen that As well....To elaborate on what Cogsman was justs saying....On M32's with out a Y2 Axis more than a couple years old....Y2 is actually TI...If you try calling a Y command when not in milling interpolation the control will take a Y command but will try to move the TI axis to where ever you told it...with the Turret still clamped....if you lucky TI will overload before any damage is done...but not ussually the Case..this shouldn't be the case on any newer M-32's I believe this has been addressed by Citizen... |
#22
threadmilling with CZ is cake RAPID TO C0 Z-(CLEARANCE) AND X0 FEED INTO THREAD FULL DEPTH FEED INTO WALL AT LOW FEED (MAJOR-TOOL DIAMETER) F~1.0 W-(2*PITCH) H-720.. (SPIN TWICE ) RAPID TO X0 GET OUT OF HOLE WORKS GREAT, BEEN USING IT FOR YEARS, THE GREAT PART IS THE X OFFSET SETS THREAD DIA, DON'T HAVE TO MESS WITH THE R OFFSET |
#23
Swiss-Tech is using a live thread mill as a single point boring bar, but using inch per minute and one C rotation per pitch in Z(incremental). this works great on center. Thread mills may be expensive but I have got over 40,000 full thread form parts off one mill in Titanium using this method(4-40,2-56,0-80). Different parts require multiple methods. Also You can use G32 if your machine Spindle can be commanded low enough to get the proper surface footage(G32 taper off on the hypotenuse). Off or on Center I tend to start in mill interp(G12.1) much like the program posted. Last edited by PacNWSwiss; 04-19-2008 at 10:13 PM. |
| Thread Milling | Don Clement | Tormach PCNC | 23 | 08-01-2011 06:48 PM |
| Thread Milling | ragman | General Metalwork Discussion | 2 | 02-04-2008 09:04 PM |
| Y axis thread milling | mroy0404 | Daewoo/Doosan | 2 | 12-21-2007 12:57 PM |
| Thread Milling on a 5 axis lathe | Jr. Programmer | G-Code Programing | 8 | 07-28-2007 07:09 AM |
| Thread milling, can anyone help | jtrav | General CAM Discussion | 16 | 03-06-2006 02:25 PM |
