| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
| CITIZEN E-serie (MITSUBISHI system) Hello everyone! I’ve question about programming this machine (MITSUBISHI system), what function I must use too drill through hole by cylinder. The spindle must be STOP, and movement on axis X & Z, using the angle holder. thank's for answer. |
| If the spindle is stopped and you are using the #1 Turret with X and Z, it would be G711. If you use the upper, or #2 turret, it woudl be G712. |
| I use this program for the angle drill holder but its for drill on the sub side and I am only going half way thru. G630 G632 (0.125 70DEG HOLES 0.600 DRILL PT TO COLLET ) M48C0 T2500 G50U-0.850W-2.545(tool shifts) G98M83S4=4500 G0X0.449Z0.129T25(x start point and z start point) /B4 #100=0 WHILE[#100LT360]DO1(i am drilling 4 times "loop") G0X.449Z.129 C#100(changes #100 = to C axes Deg) G1A-70.0X0.300F5.0 G0X0.449Z0.129 G1A-70.0X0.0F5.0 G0X0.449Z0.129 #100=#100+90 END1 /B4 G0X0.600T0 G50U0.850W2.545 M85 G99 |
| if you want to use it for the front turret on guide bushing it would look like $1 G610 G620 G610 $2 G610U1W1 G620 (0.125 70DEG HOLES 0.600 DRILL PT TO COLLET ) M18C0 T2500 G50U-0.850W-2.545 G98M83S4=4500 G0X0.449Z0.129T25 /B4 #100=0 WHILE[#100LT360]DO1 G0X.449Z.129 C#100(changes #100 = to C axes Deg) G1A-70.0X0.300F5.0 G0X0.449Z0.129 G1A-70.0X0.0F5.0 G0X0.449Z0.129 #100=#100+90 END1 /B4 G0X0.600T0 G50U0.850W2.545 G0X7.05 M85 G99 G610 make sure on $1 right before you want to drill make sure you stick the Z out cause on G620 the turret is going to position for Z. Just look up G620 in win-cnc. The reason i wrote G620 its because on the citizens they use the G600 codes. If you have one that is older the G610 & G620 would be G710 and G720 |
| Sorry please don't forget to que up $3 also |
| Yes and no.... on E series they use G700 commands, so your G610, G620, would be G710 etc. Secondly, if you stick the part out to do the angle work, then Superimpose G(7)620, then yes, you can do it this way, but if you are simply drilling with turret, whether it be angled or straight face, you could use G610 (G612) just as easily. |
| Also, in G620,720, you need to have ths stock stuckout far enough so that you can do the work. If you do this in G710, you use Z1 in conjunction with the X axis of the turret you are using, and in this case, lets say the upper one, #2. I can't read you rprint, but lets say it is a 80 degree angle. Set your tool at 80 degrees and program away, but it would look like this: $1 G710U1W1 G712 T2200 M5 M18C0 G50W U (uSE APPROPRIATE SHIFTS FROM pRESETTER) G0X#814+.1Z-.1T22 M80S3=2000 Z.5 PROGRAM YOUR DRILL HERE G0X#814+.5T0 M82 G50 CANCEL SHIFTS G700, OR WHATEVER MODE YOU CHOOSE TO GO TO $2 G710 G700 $3 G710 G700 |
| Thank YOU all for answer! could You tell me what's the parametr A? |
| G710U1W1 ON $1 I WOULDN'T START OUT WITH G710U1W1, I WOULD UNDERSTAND G710U1 TO MOVE X ALL THE WAY HOME BUT NOT W1. |
#10
| Correct You would NOT use "W1" in $1 or the stock will go back toward your barfeed and if you have a full length bar you will move the barfeeder or the machine. Something will give! |
#11
| what do you mean by parametr A? in my program A would be the angle you are trying to drill at. you just to draw it the part out and figure you start and end point for z. you position x and z start point then you would go A-45 X.??? if you are drilling a 45 deg angle. then just go back to your xz start point the go back in A-45. X.???. in my program i am using an endmill due to the problem that i was getting a real bad burr with a drill and i only did it in two passes to break thru the i.d. |
| Citizen CAV barfeeders | EdgeCrusher | CNC Swiss Screw Machines | 5 | 11-03-2007 11:04 PM |
| FANUC,HAAS,SINUMERIK,MITSUBISHI CNC system Simulation | ziyoo | Product Announcements & Manufacturer News | 0 | 08-07-2007 05:40 AM |
| RFQ - Mitsubishi Spindle Controller & Numerical Control System | cee | Mazak, Mitsubishi, Mazatrol | 1 | 06-23-2007 01:27 AM |
| VM serie machine owner? | Wiseco | Haas Mills | 0 | 05-01-2007 02:51 PM |
| Z-axis Problem Bridgeport CNC serie 1 | Rufan | Bridgeport and Hardinge Mills | 5 | 08-09-2005 09:31 PM |
