Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 12-10-2007, 11:42 AM
cseely is on a distinguished road
pick off on citizen f12
I picked up a old citizen f12. Can someone tell me how the pick off works. Does it rotate? Can it make a part with no cutoff tit?
Thanks for the help.
Old 01-09-2008, 12:12 PM
chunkymonkey is on a distinguished road
if you have win cnc, you can learn a lot about that for your machine. you might try starting both spindles in the same direction and use
G750- Pick up part with sub spindle mode. First G750 will queue with
$1 and $2, then X1 will move to return position(all the way up
safe), or optionally you can leave X1 at it's currant position
by using "G750Q1" in $1. Z1 is not moved. Next the sub spindle
will rapid in front of the part and automatically feed onto the
correct pick up position by using information from the
machining data page. If the part length is 2.0" and the back
spindle chuck position is .75" then Z2 will feed on 1.25" from
the end of the part. It is a good idea to have the cut-off tool
in place and ready, then command G750.
$1 $2
G750(Q1) G750 W.05 F80.
Q1= Only in $1. Q1 will not move X1 to a safe position. If
no Q1 then X1 moves to return position.
W.05= Rapid the sub spindle .05 away from the front of the part.
F80.= Feed rate to move to chucking position.
$1 $2
G700 G700
T1200
G0X1.3Z-1.5T12
!L1 !L1
M3S1=2500M24S2=2500 M72
G750Q1 G750W.05F80.
!L2 M15
G1X-.1F.002 M73
M5M25 !L2
!L3 !L3
G53Z4.9213(125.mm)
Old 01-09-2008, 12:13 PM
that didn't post to well, so try looking at win cnc program
Citizen CAV barfeeders EdgeCrusher CNC Swiss Screw Machines 5 11-03-2007 11:04 PM
Citizen tool pre-setter yoopertool CNC Swiss Screw Machines 13 09-18-2007 07:54 AM
DPRNT on a Citizen with a L25/32 CONTROL mistux General CNC (Mill and Lathe) Control Software (NC) 0 08-20-2007 04:26 PM
How to operate a Citizen FL-42 Twistr General Metal Working Machines 0 12-27-2006 06:23 PM
Milling with a Citizen C16 Koalas General CNC (Mill and Lathe) Control Software (NC) 6 03-22-2005 02:22 AM
