Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 10-15-2007, 11:28 PM
L. Sakthivel is on a distinguished road
Tornos - Bechler Bar Feeder Activation
Dear Friends
We are imported Used Tornos - Bechler ENC 162 Swiss type lathe With Fanuc 0T control. Bar Feeder working manually But how to operate in Auto mode Program.
Old 02-10-2008, 03:13 AM
coba2000 is on a distinguished road
need also help on this one
Hi:
We also brought tornos ENC164 (Y.1995) and FMB mini turbo 4000 bar loader.
Everything gets fine in manual mode, except in auto mode....the end of bar signal doese't semms to reach the auto mode, that the bar can be changend.
Strange...with M60 function in MDI mode, i gan change bar easily. In Auto mode, when the program is running, the end of bar signal won't work and mascine is continuosly runnign with the rest of bar. Ayone can help with this?
THX
Old 02-17-2008, 02:50 AM
we made partial solution
It seems, that one of the i/o cards on Tornos machine is faulty...it does not send or receive the signal of "end of bar", that the loading of the new bar can be made in means of normaly programming by tornos instructions. Bar loader is FMB mini turbo.
By luck, there is a macro that can be called from machine (G160 H9918), that loads the new bar without any problem. The solution must be made in folowing order.
Write a generic program without any Tornos preparations (g160 h9901...etc), make it last for a n-times (nr. of pieces/bar) and than let it run G160 H9918. It worked for me.
If someone looks for more guidelines, let me know.
Old 12-16-2011, 08:41 AM
mflint1 is on a distinguished road
Does anyone have a program example for a late 90's Benchler Enc162 with a multibar barfeeder? I program lathes,I need to learn this old machine and do not understand the program format.
Servo 300 Bar Feeder wudbutcher Haas Lathes 18 08-24-2010 11:17 AM
Need Source - Tornos Screw Machine Parts kend General Metal Working Machines 1 06-12-2009 03:22 PM
MTA 541 Bar feeder DocHod General CNC (Mill and Lathe) Control Software (NC) 0 10-02-2007 11:03 PM
SIEMENS 810D PC CARD activation ??? lentrisca General CNC (Mill and Lathe) Control Software (NC) 0 03-03-2007 06:17 PM
Activation switch question Toolmaker General Electronics Discussion 6 11-28-2005 03:28 PM
