Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 09-17-2007, 05:03 PM
Deco_2000 is on a distinguished road
Smile finaly
Finaly somebody had the idea to creat a room only for swiss type machines. I think it is really good for the forum.
I just got a new Nexturn SA-20e, anybody has experience with this type a machine. I'm looking for examples, structure of program.
Thanks for your help,
Old 09-18-2007, 06:37 AM
jorgehrr's Avatar
jorgehrr is on a distinguished road
I'm with you.
I work with Lathes ( Miyano, Nakamura) and some times with machine centers, but starting next month I get four "decos". ( I know nothing about it)
I see a lot of variables and some Fanuc in those programs, is going to be fun.
I'm sure will find help in the forum.
Be in touch
jorgehrr
Old 09-18-2007, 11:50 AM
if you need help !
I'm teaching in on Deco 10 and 13 so ask if you have any problems. I would be happy to help you.
See ya,
Cédric
Old 09-19-2007, 11:48 AM
jorgehrr's Avatar
Cool.
I'm still working with regular lathes but I am reading a book about Decos. I would like to understand the structure of the programs, I see a lot of variables and G code, not to many samples in my little book.
Do you know where I can get samples and anything about programming the Decos????
Thank you in advance.
Jorge
Old 09-19-2007, 12:45 PM
jorgehrr's Avatar
Cedric -
Do you have to use software for programming, if yes what do you use??
Jorge
Old 09-19-2007, 02:40 PM
Info about it
Well if you need some examples I can send you some. But for that you will have to tell me with which version of TB-Deco do You work ? TB-Deco is the software which alows you to program the machine. The Deco 2000 are not build with CNC numerical control but PNC syteme. It's a little bit different than Fanuc you just have to know the basics.
What kind of machine do you work with Deco 10, 13, 20, 26 ?
See ya,
Cédric
Old 09-19-2007, 07:39 PM
jorgehrr's Avatar
Great!!!!
I'll check that tomorrow at work and let you know.
I really apreciate it.
Jorge
Old 09-20-2007, 09:30 AM
jorgehrr's Avatar
Hi Cedric.
We have three 20
and one 13
Isn't this number only for capacity in mm. I'm assuming programming should be the same regardless of the size of the machine... right???
If files are to big here is my e mail
jorgehrr@gmail.com
Jorge
Old 11-05-2007, 07:25 PM
eunpark424 is on a distinguished road
still need help on Nexturn program?
Old 11-06-2007, 02:50 PM
Why not
Why not. I would like to see how do you program it. I did not like the different methodes from the instruction. I guess I found at least three. So I decided to make my own one.
But if I could compare it could be good.
  #11   Ban this user!
Old 01-04-2011, 10:00 PM
reamonpgh is on a distinguished road
They are pretty much the same. The exception would be the back working or pickoff spindle. The spindle moves in -X- and -Y- axis on the 20mm and the tools move on the 13mm. Therefore, you would program all of the outer diameters in negative on the 20mm and positive on the 13mm. Also, the parts ejection is slightly different on both machines.
Finaly.. my hobbyCNC kit has shipped Zantrin CNC Wood Router Project Log 3 12-23-2005 09:35 PM
finaly started corrie DIY-CNC Router Table Machines 13 06-11-2004 02:05 PM
