| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Does anyone have experience in programming a Miyano BNC 34t? I think it has a fanuc OT control. We recently purchased one from a customer. They have been running it for years but never used the sub turret. Nobody there can show us how to program it. Perhaps someone can send along a sample proogram. Are there any parameters that we need to change? Anything else you can tell me? Any help/info would be greatly appreciated. |
| The simplest way to use the sub-turret is G110 followed by Gcode for the B axis: (older models didn't have B-axis offsets so prog would have larger numbers) G110 G0 B.1 G110 G1 B-.5 F.01 G110 G0 B.1 A more complicated way is writing the code between G100 and G101 and utilizing wait commands (M90?) between the main and sub-turret. Too complicated to explain here, hopefully you can find a manual. |
| G101 (Begin registration of sub-turret program) T101 G0 B.1 G1 B-.5 F.01 G0 B3.5 M90 (sub turret waiting command) G100 (End of sub-turret program) G0 G40 G97 S1200 T0202 M03 G0 X1. Z0. G1 X 0. F.007 G0 Z.1 X1. M40 (execute sub-turret program (or is it M41?)) G1 Z-1.0 X1.06 G0 X5. Z5. M90 (main prog. waiting command) M30 When an M90 is read from either main prog or sub-turret prog, that axis stops action until an M90 is read from the other prog. The sub-turret program is not shown on the CRT while machine is executing program. I think G110 T101 indexes to station 1 on sub-turret. (T102, T103. etc.) Again, using G110 is simple "one shot" programming and simultaneous machining of both turrets does not occur. Last edited by bborb; 09-04-2007 at 08:03 AM. Reason: typo |
| Keep in mind that in order to keep a good cycle time is good to overlap operations (turning and drilling) M90 will be the waiting commands that will avoid crashes. You will always need a least two, one in the B turret program and one in the main program Good luck |
| Dear sir i have a miyano ANC45S i lost the parameter of this machine can you send me the parameter 900 to 940 of fanuc control OTT Thanking you Parveen kumar kaptronindia@gmail.com |
| Hmm Im almost 100% sure the miyanos I have are bnc34t's and that the turret tools are called with m61 to m66, and offset calls for these tools are done VIA the auxillary page using t71 to t7x, with t70 being the offset cancel. "sub programs" are stored between blocks g101, g102, g103, and g100, allowing a total of three sub programs to be stored to memory. You call each with m41 m42 and m43, with m90s in there as wait codes. I've done a lot of simultaneous machining with it, its great fun making a machine older than myself do things even the veterans didn't know was possible ![]() Be very careful running through single block or in dry run. Sub programs do not run in dry run, ie. They run full rapid, and if you're in single block make sure you do not turn off or on single block during a sub/main program execution. Wait until the B is done or some weird wonky potentially tool breaking things can occur. |
| Sir Denis Nayland and bborb are spot on correct. We run a line of Miyano34t's. This is the exact way we program. We have to input M90's (waiting codes) so as to overlap certain operations (drilling/centering/turning/grooving). We have been running parts on them for 20 years! They work okay, but it's nice to have a more advanced machine. I program Tsuagami's, Mori's and Daewoo's now. The Miyano 34T's are much more archaic, but they do a wonderful job with certain parts. I grew up on them and I love them. I hope the machine works out well for you! Good Luck.
__________________ Progressive Turnings, Inc. www.progressiveturnings.com |
| Miyano TSV25 | handasee | General Metal Working Machines | 2 | 12-20-2008 02:01 PM |
| Miyano cnc | gashbourne | Fanuc | 3 | 02-05-2007 04:58 PM |
| Miyano parameter Problem | AFX | Fanuc | 12 | 02-01-2007 02:28 AM |
| is a miyano mtp-3 non existant ? | dt38k | CNC Tooling | 0 | 12-20-2006 09:29 PM |
| Miyano BND-34S Programming Help | JerryH | G-Code Programing | 1 | 10-09-2005 09:11 PM |
