Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
  #13   Ban this user!
Old 09-18-2007, 05:41 AM
jorgehrr's Avatar
jorgehrr is on a distinguished road
Yoopertool -
I'm sorry I just realize I gave you the tips for machine centers.
I apologize.
Jorge
  #14   Ban this user!
Old 09-18-2007, 06:54 AM
cogsman1 is on a distinguished road
Mdi
You can always set your turret tools using MDI. Clamp on known dia. Call tool with no offset and command "X" to go to dia. Slide tool out against dia and lock down. For the "Z" zero you must first face the part with the tool that creates your "Zero" then do the same in MDI
T2200
G0 X.875
(SLIDE/MOUNT TOOL AGAINST MATERIAL)
T2200
G0X0
Z0
(SLIDE TOOL AGAINST FACE)
HIS IS HOW THE MACHINE IS DOING IT IN THE PREP MODE.
Mach3 and Tool Setter ints99 Mach Mill 1 07-31-2010 05:29 PM
What will cause this tool setter problem? Hogger Daewoo/Doosan 3 01-03-2007 07:52 AM
Setting up a Tool Setter. Smackre Mach Software (ArtSoft software) 6 06-16-2006 10:41 PM
50 taper tool setter utengineer04 Work Fixtures and Hold-Down Solutions 4 09-12-2005 02:16 PM
tool setter ACME General Metalwork Discussion 8 07-30-2005 11:15 AM
