Results 1 to 5 of 5
Thread: Citizen L20 error codes 4 and 17
    Apr 2009
    Exclamation Citizen L20 error codes 4 and 17
    Hi there,
    We just purchased a 1995 Citizen L20 Screw machine with Mitsubishi control. Our electrician just wired it up this morning and on startup I am getting this error:
    M02 Need R.P. RTN 0004
    I've looked through the machine manual but it is not very helpful when it comes to alarms. Any ideas? I don't have any previous screw machine experience.
    Registered SirDenisNayland's Avatar
    Oct 2011
    I don't know the exact alarm by number but deciphering the words your machine needs a reference point return. Again I don't know the control for that particular year model but you should be able to find the procedure in your manual
    Cheers
    Also make sure you have the three machine manuals, programmers, operators and maintenance, as well as the mistubishi manuals, there should be one dedicated to alarms/parameters
    Apr 2009
    Thanks for posting SirDenisNayland,
    I dug through my Cincom manual (the seller did provide me with all of the manuals) and found the zero return section which is attached for the next guy looking to fix this. It took a few tries, half of the directions are to turn parameter 9 off which allows you to zero return the axes. Once that was turned off you jog each axis in the negative direction until the dog switch is tripped. I did Xv, Xh and Z on the main and then hit the subspindle button and did Xb and Zb, and then turned parameter 9 back on. Problem fixed.
    Attached Files Attached Files
    Oct 2011
    No problem, glad to hear you got it all figured out.
    Apr 2009
    Man that manual page reminds me of my old 1984 L16 manual. Actually is alot more clear than the L16 manual.
    I still am surprised that I was able to decipher that gibberish. Taught myself how to run it just by the manuals when I was 16. But with no C or sub, have not come across a part I could make on it in the last five years.
    The manuals have certainly improved since then, but the machines are much more complex now too.
    1. Newbie- Citizen L20 Alarm codes
      By Q Special in forum CNC Swiss Screw Machines
      Last Post: 07-12-2012, 08:44 AM
    2. Error Codes on Servopack.
      By kjferg in forum Servo Motors and Drives
      Last Post: 08-30-2011, 02:41 PM
    3. Need Help!- Citizen A32 Z70-0001 Zero position error
      By smellyfeet in forum CNC Swiss Screw Machines
      Last Post: 06-15-2010, 08:20 AM
    4. Error Codes
      By MegaMoog in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 05-24-2007, 10:08 PM
    5. Error codes
      By Jenks in forum Commercial CNC Wood Routers
      Last Post: 03-13-2006, 07:39 PM
