Results 1 to 6 of 6
Thread: wtf? does this look like it would work to you?
    Mar 2012
    O4444(TEST FOR AUTOMATIC)
    $1
    M9
    G113G99
    G50Z-.015
    M6
    G4P1000
    #501=[#501+1]
    IF[#501EQ3]GOTO10
    IF[#501EQ6]GOTO20
    IF[#501EQ9]GOTO30
    IF[#501EQ12]GOTO40
    GOTO2000
    N10
    #2701=.001
    GOTO2000
    GOTO2000
    N20
    #2701=.002
    GOTO2000
    GOTO2000
    N30
    #2701=.003
    GOTO2000
    GOTO2000
    N40
    #3000=1(TOOL LIFE UP)
    GOTO2000
    N2000
    G0X.5Z-.05
    M3S1=2000
    T100(FRONT TOOL)
    G0X.5Z0T1
    Jan 2005
    That will work. You could ADD the line to reset #501 to zero when tool life is up to save you from having to do it manually.
    N40
    #501=0(************************)
    GOTO2000
    Jan 2005
    You MUST put the reset BEFORE the alarm. My BAD!
    N40
    GOTO2000
    Mar 2012
    thanks much. I did have some minor hang ups though, some how the machine
    ignored the math portion altogether when i put the "n10" etc. statments in the main body of the program. so finally the proven example looks like this
    $1
    M9
    G113G99
    G50Z-.015
    M6
    G4P500
    #500=[#500+1.0]
    IF[#500EQ3]GOTO10
    IF[#500EQ6]GOTO20
    IF[#500EQ9]GOTO30
    IF[#500GT12]GOTO40
    N200
    G0X.5Z-.05
    M3S1=2000
    T100(FRONT TOOL)
    G0X.5Z0T1
    G99G1Z.05F.002
    G0X.625T0
    T600(CUT OFF .047)
    G0X.6Z.050T6
    M3S1=2000
    G99G1X-.05F.004
    M8
    M8
    /M98P8999
    M9
    M9
    M25
    M119
    M5
    M7
    G0U0Z-.015T0
    M56
    G600
    G999
    G600
    N999
    M2
    M99
    N10
    #2701=.001
    GOTO200
    N20
    #2701=.002
    GOTO200
    N30
    #2701=.003
    GOTO200
    N40
    #500=0
    GOTO200
    $2
    G600
    G999
    G600
    N999
    M2
    M99
    $3
    G600
    G999
    G600
    N999
    M2
    M99
    $0
    A
    #814=0000001560
    #815=0000002000
    #816=0000006000
    #817=0003000000
    #822=0000000007
    #824=-000000500
    #818=0000008000
    #819=0000001000
    #820=0000000000
    #821=0000010000
    #990=0000005000
    #991=0000063000
    #893=0000000000
    Apr 2009
    What are you machining that you get 12 parts for tool life?
    I get cranky when I have to change an insert once a day... haha.
    Registered SirDenisNayland's Avatar
    Oct 2011
    Quote Originally Posted by danrudolph View Post
    yeah seriously
    rather than fiddling around with funky programming id rather solve the issue at its source.. unless you're machining 1" diamond down to .1" in one pass over a footlong length I dont see how you're only getting 12 parts lol *shrug*
    interesting method though!
    1. Work holding options to hold thin round work? .024, .046 etc
      By KyleH2 in forum General Metalwork Discussion
      Last Post: 06-07-2010, 02:22 PM
    2. Need work
      By denmar in forum Employment Opportunity
      Last Post: 07-10-2009, 12:03 PM
    3. Newbie- Work Planes / Work Coordinates
      By MICFDI in forum Esprit
      Last Post: 05-12-2008, 12:35 AM
    4. need work.help.
      By rscabeza in forum Employment Opportunity
      Last Post: 09-14-2007, 10:46 PM
    5. Need DXF Work Done
      By lal19541 in forum Employment Opportunity
      Last Post: 08-29-2007, 05:45 PM
