Results 1 to 4 of 4
Thread: run out issues
    Jan 2011
    us
    run out issues
    Hello. I'm trying to make a 5.3 long part on a sr-20 screw machine. The part has a .160 diameter 2.5 long. .There are two 7/16 diameter,one at the end of the .160 diameter and one at the end of the part and the middle is .215 diameter. The Stem is allowed a little bit of run out but the body has to run true within .001 to each other.. I'm getting about .0025-.0035 run out on datum A which is the two 7/16th diameters.
    I'm not sure what to do here. The guide bushing is set right,no out of roundness at all. My cutting tool is a .004 nose radius and on center. Any help would be greatly appreciated. Thanks
    May 2010
    I would start by tightening up the guide bushing little bit's at a time. Even though it may feel right there could be crap in it giving a false feel. Next would be your turning insert, I think the 4r is good but have you tried different geometry's? A little more info would help too, rpm, material, process.
    Jan 2011
    us
    Thanks for your reply. The material is 3/16 ss and is precision ground half inch diameter. The insert I'm using is a high rake Kyocera.
    Jul 2006
    Is it A runout issue, or is the part bending, are you turning everything with the same tool? Are you turning in one pass, if not, make sure your not doing any Z moves that could be pulling the stock out of the Guide Bushing.
  1. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-29-2011, 10:23 PM
  2. Newbie- EMC Issues
    By highwaymancnc in forum LinuxCNC (formerly EMC2)
    Last Post: 05-05-2008, 03:49 PM
  3. IKO issues
    By alexis221 in forum Linear and Rotary Motion
    Last Post: 03-21-2008, 06:32 PM
  4. VTC-41 issues
    By rond in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2006, 07:25 PM
  5. MDI & t & s issues?
    By howling60 in forum CamSoft Products
    Last Post: 02-24-2006, 11:27 AM
