Do you have a 4 line, or 8 line system? If it's a 4 line, you'll have to use M61, M62, M63, M64. We have 3 20's, and 2 of them have the 4 line, and one the 8 line-------------John
Hi friens I am tryin to set a Cool blaster system on a L720 lathe machine.
The deal is that I set all in place, then when I input the "B" codes on the MDI mode , the pump dont do anything.
I have more than three days working with Thecnical support but loocks that nathing will happen sunner.
Does any body have hade this type of problem when setting it systems?
Abraham C.
Try turning the coolant on manually or if in MDI turn flood coolant on by code first, single block, otherwise by default it will not turn on...not sure if you're using an older machine or fanuc so it's hard to say ATM, I don't do that crap anymore myself, I let the shop owner deal with that.
One thing that seems to be forgotten most is the need for an IO card in the machine. No card, no communication.
www.atmswiss.com
Well I have a five lines system.
You coul see it on coolblastersystems.com
Hope you know it.
Thanks for your help
Abraham C.
Thanks for the answare, I did it before but not good results.
Abraham C.
The five line systems use the B codes for on-off.
First things first..................
Does the pump run when you turn the machine coolant on? The high pressure system pump should start when you turn on the machine coolant pump.
www.atmswiss.com
Dont work by turning the coolant from the lathe, neither with the B codes.
When I try with MDI mode from the lathe, the page get freeze trying to send the order to the h. presure pump.
As you know, after to write the B code in MDI you have to push the stat buton, so the late sends the signal to te pump, but it screen just guets stock.
Abraham C.
Yes I do have power on it
Abraham
OK....did you install an I/O card in the lathe?
www.atmswiss.com
here are some pictures of the board and the parameters.
