Results 1 to 3 of 3
Thread: Question Help me improve this custom macro, also freebie chip breaker macro for lathe
    Registered MCImes's Avatar
    Sep 2011
    Question Question Help me improve this custom macro, also freebie chip breaker macro for lathe
    Hello,
    This custom macro was set up by the factory on a couple of our swiss machines to help control chips. It works awesome so feel free to use it if you have some unruly chips.
    As the program exists you can only turn in Z. This works fine most of the time but I would like to be able to program in some taper in X. Could you guys tell me if this would be possible?
    All it does is turn/dwell/turn/dwell ect.
    Z=end
    Q=turn distance before dwell
    D=Dwell in seconds
    F=Feed
    Here is the existing program:
    O0061(G1 MACRO: SET PARAMETER 6050 TO 61)
    (CHANGE TO O9010 WHEN INSTALLED)
    IF[#7LE0]GOTO5
    IF[#9LE0]GOTO6
    IF[#17LE0]GOTO7
    IF[#26LE0]GOTO8
    #501=#5042
    IF[#501GT#26]GOTO10
    WHILE[#501LT#26]DO1
    N1G01Z#501F#9
    G04X#7
    #501=#501+#17
    END1
    G01Z#26F#9
    M99
    (CUTTING Z+ TO Z-)
    N10
    #501=#5042
    WHILE[#501GT#26]DO1
    N1G01Z#501F#9
    M99
    N5#3000=1(D MISSING)
    N6#3000=2(F MISSING)
    N7#3000=3(Q MISSING)
    N8#3000=4(Z MISSING)
    _______________________________________________________________
    So, here's my (uneducated) thinking on how to improve this
    #501=#5042---------------------- (#501=current Z position)
    #502=[[#26-#5042]/#17] ---- [turn length/peck distance] (formula to get # of "pecks")
    #10=#503------------------------- (didnt look up what # U actually is so its 10 for this example)
    #503=[#503/#502 ] -------------(per peck U move)
    WHILE[#501LT#26]DO1
    N1
    G1 Z#501 U#503 F#9
    G4 X#7
    #501=#501+#17
    END1
    G1 Z#26 U#503 F#9
    M99
    Could this work? thoughts? thanks!
    Process Development machinist / CNC training consultant
    Feb 2012
    You don't need to use #10; you can simply use #503 and enter the amount of taper compensation you would like to see. The #10 will work however, though you will still need to use #503 to enter the amount of taper adjustment. Please note that if you have "#503=(any value here)" in your program, it will reset to this value any time you run through your program even if you attempt to make an adjustment to #503 on the variable page.
    Jun 2012
    macro help???
    Hi everyone,
    I know that my question maybe will be to simple for someone, but I need help anyway.
    I want to create a macro that check the axis position during the g-code execution and if it is in exact position turn the output ON and in another position turn the output OFF.
    Any help will very appreciated.
    thanks
    darli
  1. Problem- Question about Custom Macro AGAIN!!!!!
    By ixoxi999 in forum Fanuc
    Last Post: 04-25-2012, 04:19 AM
  2. Replies: 3
    Last Post: 02-13-2012, 01:20 PM
  3. Help writing chip breaker custom macro
    By MCImes in forum Fanuc
    Last Post: 10-31-2011, 12:34 PM
  4. custom macro question
    By sinha_nsit in forum G-Code Programing
    Last Post: 04-18-2009, 07:44 AM
