Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 01-11-2012, 06:21 AM
chet470 is on a distinguished road
STAR SR20 RIII
Has anyone noticed that G87 doesn't work on the Star SR20 RIII? I have heard that the cross peck drilling cycle doesn't work on this machine. If anyone knows for a fact either way I'd appreciate to hear from you.
Old 01-11-2012, 05:27 PM
MCImes is on a distinguished road
Im not sure about the G87 but if you have a floating holder this is a good working macro taping program:
T0303(4-40 CROSS TAP)
G50W-.194
#100=350 (RPM)
#101=.025 (FEED/pitch)
#102=[#100*#101]
G0 G98 X# Z# M23S#100 (cross tool on clockwise)
C0. (or c whatever)
G4U.5
G1X-.36F#102 (X end depth)
M24S#100 (cross tool CCW)
G4P5
X.3 (X above stock)
G0X1.496 T0 M25 (X home, cross tool off)
G50W.194
M51
If you break a tap reduce the feed from actual to 90%, if that breaks reduce feed to 80%. Actual pitch usually works but a couple times ive had to use 80%
Let me know if that works for you
I program, setup and run Swiss lathes with Fanuc controls
Old 01-13-2012, 07:04 PM
SirDenisNayland is on a distinguished road
I don't think I've ever heard a more ridiculous statement. G87 most certainly works.
Old 01-15-2012, 09:45 AM
PixMan is on a distinguished road
It's been over 4 years since I last programmed, setup or ran one of those, so forgive my probably ignorance.
It is not unusual for Star to have modified the basic G87 into something like a G287 using the available Fanuc custom G-code function. That's especially likely if the application is needed for the cross-working tools that have to peck in the Y axis. Check your documentation.
Old 01-18-2012, 05:30 PM
awarner123 is on a distinguished road
G87 cross pecking cycle
I had this problem years back with a SR-20 RII. Turns out when I programed
G87 it seemed like it just went to the bottom of the z stroke in rapid. (and of course the drill broke) Turns out it was a parameter setting. It was set for high speed pecking. So I suggest checking out your parameter manual or calling you Star Rep to find out what parameter to change. Hope this helps.
Old 01-22-2012, 06:00 PM
petriej is on a distinguished road
Check your coordinate system. On the RII there are G17, G18, G19, G117, G118, and G119 CS's. It will do exactly as you say if you don't change to the correct coordinate system. I think that it's G118 if you're using 3100-3500.
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
THK SR20 linear guide question vpl DIY-CNC Router Table Machines 4 10-24-2010 06:18 PM
Need Help!- Star SR20 Macro question jrob69 Rams Software 2 10-18-2009 07:26 PM
SR20 STAR Lathe jrob69 CNC Swiss Screw Machines 5 03-12-2009 08:19 PM
Need A Quote- Star SR20 jrob69 Employment Opportunity 3 08-20-2008 11:52 PM
Looking for THK SR20 Bearings (cars) southernexplore Linear and Rotary Motion 1 01-31-2006 05:25 AM
