Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 12-29-2011, 09:55 AM
DCogswell is on a distinguished road
Machining Molybdenum
Anyone ever run molybdenum on their swiss-type? I may have an application that needs this material. I've never machined this material and I'm curious to see if it's possible on a swiss cnc.
Old 12-29-2011, 11:31 AM
A1CNC is on a distinguished road
I haven't run it on a swiss but, I had some moly parts that were turned and milled.
It is chippy, The threads were hard to get a good finish on.
Old 12-29-2011, 01:10 PM
hacdlux is on a distinguished road
http://www.espimetals.com/tech/machiningmolybdenum.pdf
the as sintered thing sounds a little scary through a guide bushing, and it sounds like it work hardens prettty bad
Old 12-29-2011, 03:23 PM
I read that document this morning. I don't think it's relevant to swiss in regards to turning however, the drilling suggestion seems ok.
I haven't decided if I want to quote this job yet.
Old 12-29-2011, 10:22 PM
I will only quote moly again for double my usual rate knowing it will give me double the usual grief!
China EDM Wirecutter Molybdenum franzschluter EDM Machines 0 07-11-2011 06:00 AM
Need Help!- Machining Molybdenum on a lathe Slaps Mini Lathe 12 05-31-2010 08:54 PM
Several questions (glues, drill mills, molybdenum) BFGarrett Tormach PCNC 16 05-31-2009 07:56 PM
threading tzm molybdenum goblinmonkey Composites, Exotic Metals etc 0 05-28-2008 12:24 AM
