Results 1 to 7 of 7
Thread: Need help writing program for Citizen E2-32 for long parts
    Feb 2007
    Question Need help writing program for Citizen E2-32 for long parts
    I have been writing programs for our E32 for the last year and have been doing so successfully. I have not, though, written a program in which I would have to re-chuck to make the part due to its length.
    The part I am trying to make is is roughly 6 feet long. I understand the basics of doing an "inchworm" kind of deal to get the correct length. My dilemma is what to do with Z dimensions. For instance, if I tell the machine to go to Z12., that is not a problem. When I unclamp to move Z, where do I tell it to go? Back to 0? Do I do a coordinate shift? Is there an easy way to keep the dimensions straight?
    Any ideas/help would be greatly appreciated.
    Mike
    Feb 2008
    The Edge of Obscurity
    as you are "inch worming"...
    Code:
    G0 Z10.
    (HOLD THE BAR IN SOME WAY)
    M7(OPEN COLLET)
    G0 W-10.(BACK UP HEAD STOCK 10 INCHES)
    G50 W10.(SHIFT YOUR Z COORDINATE SYSTEM)
    M6(CLOSE COLLET)
    (REMOVE THE BAR HOLDING)
    G0 Z20.
    (HOLD THE BAR)
    M7(OPEN COLLET)
    M6(CLOSE COLLET)
    G0 Z30.
    (SO ON AND SO FORTH)
    (AT THE END )
    G50 W-{TOTAL OF ALL THE APPLIED SHIFTS}(CANCEL ALL SHIFTS)
    M7(OPEN COLLET)
    G0Z0(OR WHATEVER END POINT YOU USE)
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Feb 2007
    Excellent! That was not so difficult. Citizen made it sound lots more difficult than that! Thank you very much!
    Mike
    Feb 2008
    You're welcome, I hope it works out for you.
    Registered MCImes's Avatar
    Sep 2011
    My tsugami only has a 3" travel on the main so I will pull with the sub at the same time as I move back on the main allowing me to regrip 8" at a time instead of 3. This might work well for you considering you have a 6' part. It will save you a few pulls at least.
    Also, if your bar is slightly short does that mean you would get 1 part per bar? if so thats funny.
    It looks like this for me:
    M505 (wait code for sub to approach)
    M510 (sub in place)
    G0 Z3. (max z)
    M20 (sub close)
    G4U.4 (wait)
    M11 (main open)
    G4 U.4 (wait)
    M511 (sub moves back 5")
    G0 W-3. (main back to max z)
    M512 (sub in place, ready for main to clamp)
    G50 W8. (3" on main + 5" on sub)
    M10 (main close)
    G4 U.4 (wait)
    M21 (sub open)
    G4 U.4 (wait)
    G0 Z11. (8" pull+3" max z stroke on main)
    repeat
    Process Development machinist / CNC training consultant
    Feb 2007
    Actually, the finished part is just about 6-1/2 feet long, so, yeah. Only 1 part per bar. Fortunately our customer sent us material that is about 1 foot longer than the finished dimension so we have something to hold on to for parting off to the correct length.
    Mike
    Sep 2011
    just thought of this too... how are you measuring the length? whats the length tolerance on a 6' part?
    1. Citizen A32VII program help...again
      By sthuston in forum CNC Swiss Screw Machines
      Last Post: 10-22-2011, 08:59 AM
    2. writing g-code program for fadal vmc for tapping and drilling
      By mrivera85706 in forum G-Code Programing
      Last Post: 08-31-2011, 06:23 PM
    3. Need Help!- Looking for Program/set-up Guy in AZ for Citizen!
      By justininaz in forum CNC Swiss Screw Machines
      Last Post: 10-11-2010, 10:41 AM
    4. G Code Program writing
      By Tool Guy 1234 in forum G-Code Programing
      Last Post: 04-23-2010, 07:33 PM
    5. Need Help!- Citizen E16/20 E25/32 Program
      By gollame in forum CNC Swiss Screw Machines
      Last Post: 02-23-2009, 08:35 AM
