Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 10-25-2011, 08:00 AM
lukehonor's Avatar
lukehonor is on a distinguished road
6262 Aluminum
Hello All...
I'm drilling two .070" holes in 6262 aluminum and I'm having some problems. The holes in questions are .070" DIA and 12 X deep. They are off center and on the face of the part.
I'm running this job on a Tsugami SS32. I'm drilling from the sub-spindle, using a live tooling position. I'm using a solid carbide OSG drill with no spot. My drill is in an ER collet. I drill with a stubby pilot drill first so i have a good start for my .070" to follow. I broke three drills and i'm not more than 200 pieces into the run.
Any suggestions on how I should run my .070" drill after the pilot drill? One pass...? Should i peck...?
Thanks!
Progressive Turnings, Inc.
www.progressiveturnings.com
Old 10-25-2011, 08:56 AM
Have you dealt with 6262 before? It is a free-turning alloy and in my experience with turning and milling the chips come of in nice small flakes. But what I have found with drilling is that these small flakes jam up in the flutes of the drill and don't clear away. I haven't drilled that diameter that deep, smallest I did was 1/8", but if you haven't already tried it I suggest short pecks (1/2D?) and plenty of coolant.
Old 10-25-2011, 09:52 AM
lukehonor's Avatar
Geof,
Thanks for your input. I just programmed some pecks in there and I'm trying it now. It ran a few and didn't break. I hope it works.
Precision CNC Machining - Progressive Turnings -
80/20 aluminum gantry, milled aluminum ends 3Dsigns DIY-CNC Router Table Machines 11 10-15-2010 03:55 PM
Securing Aluminum to Aluminum webgeek General Metalwork Discussion 3 12-29-2009 05:30 AM
Bonding aluminum to aluminum - Doable? How? Arquibaldo General Metalwork Discussion 15 11-05-2009 09:01 PM
Carbide endmills Aluminum vs non-aluminum ??? zaebis General Metalwork Discussion 7 09-14-2009 08:53 AM
pressing aluminum into an aluminum tube Fishin_Rod Mechanical Calculations/Engineering Design 24 07-01-2009 12:23 AM
