Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 10-18-2011, 09:52 PM
rahman161206 is on a distinguished road
Post Tsugami BS 18 III Problem
Dear ALL,
I make program and want to trial test cut.. but seems the Z1 axis coordinat system or parameter is not suitable.
Everytime in program command for Z+ but actual movement on the machine is Z-
Now I use Rotary Guide Bush for the process. I already follow the instruction on manual book regarding the setting of rotary guide bush.
Coluld you please help me what's wrong with this machine?
For reference please refer the attached file for program I make.
Thank you for help and best regards,
Rahman
Old 10-19-2011, 03:44 PM
DCogswell is on a distinguished road
Looks fine, the over travel is somehow caused by your custom settings (rotary GB, etc.) Whatever setting you're using, make sure you have that much (100mm) travel available.
For T1414, I would omit your G50's and caution against using G50's in the future for any newer swiss types. Just goto your offset geometry screen and input the tool geometry.
Old 10-22-2011, 02:17 AM
Thanks for your reply.
Now machine can running normally.
Turns out the problem of parameters,
Yesterday all my parameters match with the list of parameters.
Parameter 12 for axis z (mirror), I change to 0
Rahman
Need Help!- TSUGAMI BS 18 III rahman161206 CNC Swiss Screw Machines 3 10-09-2011 10:15 AM
Tsugami SS32 problem lukehonor CNC Swiss Screw Machines 8 01-26-2011 11:25 AM
Need Help!- tsugami S25(D) lukajt CNC Swiss Screw Machines 0 09-21-2009 09:05 AM
Need Help!- Tsugami NM4A Tool Change problem greenery_fr Fanuc 4 10-08-2008 01:46 AM
Need Help!- Tsugami NM4A Tool Change problem greenery_fr Fanuc 0 09-22-2008 11:57 PM
