Results 1 to 6 of 6
Thread: Threads Gulling
    Sep 2011
    U.S.
    Threads Gulling
    Machine Swiss Star SR203111, Head 1, Tool Location-T1400, Operation-Tapping
    (North American 7/16-32 45deg. Spiral Flute Threadshaver) running at 20 SFM. Threads Gulling. Any Suggestions?
    May 2004
    I suggest you tell what type of material and what is the measured size of the drilled hole before and after tapping.
    http://www.kirkcon.com/
    Sep 2011
    U.S.
    Material
    The Material is 304 S.S. Tubing. I.D is .419
    May 2004
    What % of full thread are you trying to get?
    May 2004
    From Machinery Handbook:
    7⁄16–32 UN 2B Minor Diameter 0.404 to 0.411
    7⁄16–32 UN 3B Minor Diameter 0.4040 to 0.4094
    So, at 0.419 you are already oversize by at least 0.008. You will have an effective thread height of 0.0093. About 61% full thread. What you are probably actually seeing is not galling, you are seeing very rough, torn thread crests. Thin wall tubing is not very forgiving for most machining operations in my experience.
    Aug 2006
    depending on how thin your tube wall is you might be able to get awy with a form tap,
    also is there a weld seam in there ive run in to that problem before even after cutting it out
    i would single point it 304 is kind of miserable to cut threads in any way
    just did some 10mm studs in this used a kennametal laydown 5010 it cut like butter IT NEEDS A CHIP BREAKER
    1. No Threads?
      By Noesph in forum CNC Swiss Screw Machines
      Last Post: 12-16-2008, 04:47 PM
    2. Newbie- Different threads
      By johngo1 in forum Machines running Mach Software
      Last Post: 02-18-2008, 05:29 PM
    3. New threads that are not new???
      By turmite in forum Forum Questions or Problems
      Last Post: 01-27-2005, 09:52 AM
    4. npt threads
      By scubasteve in forum G-Code Programing
      Last Post: 03-16-2004, 05:37 PM
    5. Saving threads or parts of threads???
      By flybynight in forum Forum Questions or Problems
      Last Post: 02-22-2004, 01:19 AM
