Results 1 to 9 of 9
Thread: Non CNC but still Swiss question
    Registered nelZ's Avatar
    Jun 2008
    I want to make a small part with cross holes. Does anybody know if the old cam driven swisses could do such a thing? I just want to make thousands of little spindles with cross holes in them, max. dia. of .150 Inch.
    If anybody has a simple small working swiss, CNC or not that can do this, maybe sell it to me and get one with more bells and whistles you may need.
    Thanks in advance!
    i build the braces that keep american teeth straight......tick tick tick
    May 2004
    I used to run a Hardinge manual that was retrofitted to CNC that had live tooling attached in the form of air motors. So, yes, somewhere out there is a small machine that will do what you want.
    http://www.kirkcon.com/
    Registered MikeMc's Avatar
    Oct 2008
    Get a hold of Paul Huber at Comex, he has what you need.
    About COMEX - COMEX - Continental Machinery Exchange Corp.
    www.atmswiss.com
    Jun 2008
    Thanks for the Clue!
    I sent him a print.....we'll see what happens
    Do you run cam type automatics?
    Nelson
    Oct 2008
    I ran cam machines years ago, but we are all CNC now.
    www.atmswiss.com
    Jun 2008
    Thanks again for the clue Mike. I spoke with Paul and shared the print of what we need made. He doesn't recommend cam, go for CNC but I'm afraid we don't have the budget for that...60-100k...payback would be a bit long.
    Nelson
    May 2004
    Here is a link for the live tooling in mentioned.
    You are browsing a website link from smsmachine.com
    Aug 2006
    how long is the shaft?
    if all you need is a cross hole and cutoff
    you could pick up any gang tool lathe
    my second cnc was supposed to be 40k with the feeder and i had several options (btw i ended up getting an ss32)
    look up cubic cnc theyre gt mini is in the low 30s or an old omniturn
    Jun 2008
    .150 diameter spindle .75 inch long with .072 ends .046 cross holes at 90 degrees
    Thanks!
    Like this....disregard the underlines - the X's are the shape of the part
    _____XX
    XXXXXXXXXXX
    _____XX
    1. Job Opening swiss needs
      By BILL WRIGHT CCR in forum Employment Opportunity
      Last Post: 08-17-2011, 03:31 PM
    2. Replies: 15
      Last Post: 04-14-2011, 12:33 PM
    3. new to swiss
      By positiverake in forum CNC Swiss Screw Machines
      Last Post: 11-12-2009, 02:19 PM
    4. Swiss Newbie question
      By nelZ in forum CNC Swiss Screw Machines
      Last Post: 02-17-2009, 12:43 AM
    5. cnc swiss axis question
      By BAD DOG in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-22-2007, 05:28 PM
