| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hi all here is the problem the new citizens when using H cant go past 9999. So I was wanting to maybe make a (while/do) formula that can do the formula and decide how many times it needs to divide itself so I can make a universal program to work with older and newer machines. (I am Thread whirling B.T.W.) Here is what I was thinking so far. I haven't tried this yet just wanting some feedback to see if I'm going in the right direction. Example #501= Thread length #502= Pitch #503=[[[#501+.05]/#502]*360] IF[#503LT9999.]GOTO77 #504=2 WHILE[#503GT9999.]DO1 #506=#503/#504 #503=#506 #504=#504+1 END1 Basically what I want is to pass the #503 and #504 variable down to the the next while/do with the new numbers to perform the whirling as needed in increments less than 9999. (I'm just not sure if you can do it like this or if it will confuse the machine) example for the next while/do in the program. #507=[[#503/360]*#502] #508=1 WHILE[#504GT1]DO2 #509=#507*#508 X-.075Z#509H[[[#507]/#502]*360] G50 C0 #508=[#508-#504]+#504 #508=#508+1 #504=#504-1 END2 So what I am wanting this to do is create the amount of H loops I need and each one will subtract till at 0 and also I need it to add to the final z each loops so if I started off at .250 for each z the second z needs to be .5 3rd .75 etc. Not even sure if I'm even close to being right or if its even possible just wanted to through this out to some of you programing wiz's and see what you think. I know I could use G32 and have separate programs but I like to tinker Thanks Last edited by Machinist_X; 08-24-2011 at 08:49 PM. |
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
| As for how old of machine's i would say any we have from the last 6 or 7 years or so, also we installed a new motherboard on a m12 2m3 and it now wont take H past 9999. Lol Tea hole yep. No I was just wanting you guys to punch in some numbers for 501 and 502 and see if you thought it would work out b4 I tested it in a machine. Hopefully this week I will have time to put it in a machine and test it to see if it works just thought I would throw it out b4 I tried to test it to see if I was close or way wrong and needed to do it a different way. |
| There are more concise ways to achieve what you want to do. The issue is not with the machines ability to read a C value beyond 9999 but rather the softwares ability to accept an input value greater than 9999 for C or H. For that reason, you would not need to us G50 C0 in your WHILE/DO loop. Here is the basic problem at hand...
Once you determine these two things, you can achieve what you want in a single W/D loop. If you want to put some more thought into it using the above ideas, I would be happy to assist you here. If not, that's fine too, and good luck to you.
| Well, I've given you the two main components of what you need to solve your issue ... Give the info I'ver provided, what can YOU come up with that is different than what you've already done? Show some code using the new info and lets work form there. I would be happy to help you work through the thinking. Good luck!
| Code: G1 G98 Z3.7 H9999(THIS IS THE MAX INPUT FOR C OR H) 1/16=.0625 2.5 / .0625 = 40 revoloutions. 360° * 40 revolutions = 14,400° so that code would be... Code: G1 Z0 Z2.5 H14400.(THIS WILL ALARM AS THE INPUT IS OUT OF RANGE) Not a bad idea .
#10
| Sorry for the slow response back but I don't get online much but thank you very much Pro-Process for the hints in the right direction after I read your post I didn't think I would figure out a easier way but put a couple of days into thinking about what you said and it clicked. I got a nice streamlined macro'd program that I will now start using for all my whirl programs thanks again. |
#11
| Need Help!- Macro problem w/16i | marcwdci | Fanuc | 13 | 06-29-2011 08:21 AM |
| Scale math formula ? | timmydabull | Mastercam | 3 | 08-30-2008 11:50 PM |
| Drill Macro problem | toolmanwaz | CamSoft Products | 5 | 04-01-2008 10:47 AM |
| VF0E Macro Problem | stang5197 | Haas Mills | 1 | 06-14-2007 05:34 PM |
| Math Formula Required | Kiwi | Mechanical Calculations/Engineering Design | 51 | 08-20-2006 07:44 AM |
