Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 08-18-2011, 10:19 AM
pmrairokn is on a distinguished road
Star ECAS32T High Pressure Coolant!?
Hi all,
Had a quick question if anyone could help us with our Star ECAS32T. We bought the machine used which included the high pressure pump. Problem is, we can't figure out how to turn the high pressure pump on! I'm told that Air Cut mode disables the HPP. Does anyone know off hand what the M-code is or should be? M25 and M125 turn the 2 standard coolant pumps on. M150 does nothing as well. Also, is there an M-code library in the machine as well? Any help would be great. Thanks.
Old 08-18-2011, 06:00 PM
DCogswell is on a distinguished road
Our SR20R-II has HP Coolant, M161 on M171 off. However, I'm not too sure how consistent Star and or the dealers are when they set-up the M-codes for HPC.
Old 09-06-2011, 09:31 PM
dookie2022 is on a distinguished road
Flood coolant must be on and coolant 1 switch on
If its factory pressure at 1.5Mpa the factory will use M125 and coolant 2 switch on
now depending on options Star (6.9Mpa plus) will use other M codes to turn these on
They usually start around the M1004 -M1020 area if the system was supplied by the factory.
There should be documentation in the electrical manual.
I am also aware that US do not tend to get factory options and fit the systems locally.
The agent who origanlly supplied the equipment should have these details
Old 09-12-2011, 07:30 AM
billcain is on a distinguished road
Coolant codes
As with Many Manufactures, HP coolant codes dont always come from the factory and are sometimes set by the Engineer setting the machine up for delivery.
Here are some codes that are used on Ecas machines. They may or may not work depending on your set up.
HP M125/M126
Through Spindle M154/M155
M156/M157
M152/M153
Bill Cain
www.partmaker.com
Old 09-21-2011, 02:29 PM
swissdodger is on a distinguished road
On our SR32J,SR-20's and SB-16's the manuals say M151 thru M159 on, BUT for all of ours it is M161 thru M169 = ON and M171 thru M179 = OFF.
Good Luck
Tags
32t, ecas, ecas32t, high pressure coolant, star
High Pressure Coolant davek11 GibbsCAM 2 03-16-2011 10:08 PM
High pressure coolant systems CHAD LAWSON General Metalwork Discussion 3 08-25-2008 04:15 PM
high-pressure coolant 307startup Mechanical Calculations/Engineering Design 7 09-29-2007 04:40 PM
Coolant pressure cdlenterprises General Metalwork Discussion 2 08-11-2007 11:42 AM
High pressure coolant problems-corroding way lube lines Bob D Haas Mills 3 03-20-2006 08:00 PM
