| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hey, Revisiting an issue I had awhile ago when turning long shafts with geometries that made pulling chips off the part impossible. I cannot seem to find the correct insert, speed, feed for breaking long stringers on an ecas 20. Bar diameter is 3/8" turning to 0.13. Any suggestions? |
| peck turn m98 p7001 l10 (P107001 ON TSUGAMI) repeat o7001 10 times O7001 G1W.006F.002 W-.001 i have very good luck with tungaloy js (ccgt32.51) inserts started using them on heat treated steel now i use the on aluminum and everything between even breaks chip on light cuts are you pinch turning this? splitting the chip load will help last time i turned 17-4 h1150 i used an applitec 762xr20 tialn 5/8 down to .300 worked ok but i would try the tungaloy first |
| Need Help!- Keep Breaking Taps | behindpropeller | Haas Mills | 16 | 01-21-2012 09:16 AM |
| Need Help!- Breaking 1mm bits... | billturnbull | CNC Tooling | 4 | 07-19-2011 08:39 AM |
| Chip to Chip Time | Gene0552 | General Metalwork Discussion | 36 | 09-01-2010 11:05 AM |
| Need Help!- Tap Keep breaking on Aluminium | makbari | Mazak, Mitsubishi, Mazatrol | 14 | 08-22-2010 08:54 PM |
| Chip Breaking instead of full retract peck drilling | weaston | SolidCam | 1 | 05-22-2008 02:10 AM |
