| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
I have a job where I have to blend three tools precisely, a front turn, thread tool and a groove tool used to clean up the thread. I am able to get the blends perfect, but I would like to be able to then shift the X of all three tools as a group. Offsets are T03, T04 and T05. I would like to use say, T10 to adjust T03, T04 and T05 at the same time. Is there a way to do this on a Citizen A20? |
| I did a little research on this idea, here's what I came up with: In the program I could write the following at the start: #2003=[#2003+#2010] (T03 Line) #2004=[#2004+#2010] (T04 Line) #2005=[#2005+#2010] (T05 Line) Then by adjusting the X value of offset T10, the relative changes would be transfered to each of the three tool offsets at the start of the cycle. Where #2003 is the X value of the T03 offset and so on. I am not sure if Citizen is using the tool wear offsets or the geometry offsets on its single offset page? If so, those variable numbers may be different. If anyone has a better implementation, I am all ears... |
The issue with this implementation is that (I think) you would be accumulating the #2010 offest with each read, as each time you're reusing #2003/4/5 which already has #2010 added to it from the previous read. A different implementation would be to use a G50 U-#2010 to apply the value of T10 Xoffset as a shift to the X axis then cancel by G50 U#2010. Good luck.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
| Grouped Vectors Make Different Size Toolpath than Ungrouped | Lafaso870 | General Jewelry Design Software | 0 | 12-03-2010 01:06 AM |
| Problem- Problem with linked feature | sk96_me45 | UG NX | 5 | 12-01-2008 10:44 AM |
| H and D offsets | CNCMike | Fanuc | 11 | 05-27-2008 10:33 AM |
| paperclip on direct linked pictures | sendkeys | Suggestions for the CNCzone.com site. | 3 | 01-18-2005 01:21 PM |
| Linked Cable/wire Guides ???? | frinkdaddy | General Electronics Discussion | 5 | 10-25-2004 03:44 AM |
