Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 06-23-2011, 07:12 PM
PoiToi is on a distinguished road
Incessant Pneumatic Pressure Alarms on Citizen A20
Hi all,
I have a 2007 Citizen A20 that has started giving me Pneumatic Pressure alarms all the damn time.
At first I just thought it was a supply issue, but I put a little air tank with a check valve between the shop air supply and the machine, to make a little reservoir for the air pressure. It didn't really help.
I know that there is a pressure gage on the back of the machine, and if it drops below 17PSI, it will alarm. The alarm seems totally random, not just when blowing out a spindle or something (that would be easy to fix).
I was wondering if I am missing something here or of there is some way to diagnose the problem and figure out what I need to do so the pressure stops dropping so much.
thanks!
Old 06-23-2011, 07:40 PM
danrudolph is on a distinguished road
If I remember correctly, my C320 loader throws a pneumatic alarm before the A20 does. Are you getting low pressure alarm on the loader? We have the air line tee into the loader and machine from one line.
Maybe you have a faulty pressure switch?
Old 06-24-2011, 06:50 AM
g-code_junkie is on a distinguished road
ckd pressure set
These are usually set 16kpa min 24 kpa max with a nominal of 20 kpa. If you have an incoming of 17 kpa then it is, most likely, tripping low limit.If you have the A-20 with a C-320 loader there is alot of air demand and the 17 kpa might not be enough when demand is high.
good luck
My pneumatic counterbalance davo727 Industrial Hobbies (Support forum) 19 02-07-2012 02:49 PM
Newbie- Low Profile Pneumatic Chuck? GG5X Work Fixtures and Hold-Down Solutions 0 01-21-2011 09:27 AM
Pneumatic question Pukwudji Open Source CNC Machine Designs 5 05-22-2009 11:24 PM
Pneumatic solenoid help Cold Fusion CNCzone Club House 3 05-29-2006 12:46 AM
pneumatic pen mocnc DIY-CNC Router Table Machines 1 09-12-2004 09:06 AM
