| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Does anyone have any usable code for a Citizen L720 using M34 in $1 to dump the part? My part basket doesn't rotate after it enters the part chute. Also when I use M32 x.200 to catch the part the chute doesn't return home in Z2 axis. Is this normal? |
| M34-(macro) Series of commands needed for parts ejection from the P.O. spindle all in one command. Collet open, parts catcher in/out, knock out forward, air ect. This can be commanded from $1 or $2 but has two very different functions. If M34 in $1 then dump the part from the catcher mounted on the sub spindle. If M34 from $2 then eject the part from the sub spindle into the parts box. There are many command options that can be used but usually just "M34" is all you need. See the different command options below. If M34 from $1 and the part is in the catcher basket by using M32 then ... You must be in G821 mode. See M32. Also there can't be any "T3?00" in the $2 program or M34 will function like in $2 and try to knock out a part. M34 X W D U E Z F T S B M34 -nothing else on line then catcher moves away and dumps the part. X -X pos. to go to. Normaly not used. W -After the part is caught then the catcher moves back to Z0 or the amount of W from Z0. Used if Parts per 1/chucking is used to save time. Normally not used. D -Feed rate for Z2 to move away from GB. IPM U -Used to change the position of X2 at the dump position of ".156" . Normally don't use. E -Feed rate for X2 to move to the dump position. IPM Z -Move to Z position inside collection box. F -Feed rate when moving into position inside collection box. IPM T -Timer for rotation while back spindle is dumping the part. S -Spindle speed while dumping the part. RPM B -When finished move Z2 to amount B from Z0. |
| Here is the example I use. M34(Drop off) M32(Pick up) T0400(Face) M34(Basket Eject)(Drops off part when $1 starts to face) G0X.5Z0T04 G99G1X0F.0015 G0X.5Z-.025T0 And so on. M3S1=1500 G821 T0100(LH-Cutoff) G50W-.500 G0X.5Z.5T01 M32(Basket Advance) (You can also add an "X" value to cut to before the basket comes up) G99G1X-.1F.0015 G50W.500 G820 And so on. And as stated below, make sure your mc-data is set to basket. Also the type 7 machines use G610/G600 in place of G821/G820 but I have not tried this yet with the basket. Last edited by CitizenBrian; 05-31-2011 at 09:19 PM. |
| Citizen Start Position L520....L720 | chet470 | CNC Swiss Screw Machines | 5 | 06-27-2011 01:25 PM |
| Need Help!- Citizen L720 parts main spindle | jack moore | Want To Buy...Need help! | 0 | 02-11-2011 10:39 AM |
| Citizen Part Transfer | chet470 | CNC Swiss Screw Machines | 7 | 07-22-2010 11:41 AM |
| Problem- OIL DUMP! | bigfoot | General Metal Working Machines | 0 | 02-04-2010 10:19 AM |
| Dump Warning | Mariss Freimanis | Suggestions for the CNCzone.com site. | 13 | 07-04-2008 01:12 PM |
