| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
I'm posting here because you guys drill small holes. I have 50 small holes to drill .75 mm/ .03". The hole is center line of the spindle in a lathe with 3000 max RPM. I have the tools (10 circuit board drills) and I dialed the tool holder within about .0002 of the spindle rotation. I haven't tried drilling yet (monday), but do you guys use the standard formula, drill diameter divided by 1/64 for a feed, that gives .0004 per rev. And what about peck amount? Another piece of info. the hole is about 15 X the diameter. So my question is what feeds would you use for a drill this small? And what peck amount? Thank you Robert
__________________ The beaten path, is exclusively for beaten men. |
| Small holes, but in what material? Smallest drill I have is 0.25mm. Peck depth for 0.75mm, I wouldn't use above 1mm normally, but it depends on the material. Some material types clog the drill flutes. Feed? 5-30mm/min is my guess. I just start gently, and careful examination of the chips is what guides me. Stainless steel? Forget HSS. Use carbide. 3000 RPM means your feed will be slow. As your hole is quite deep, a touch start with a center drill is a good idea, even in wood. Wood has hard spots and drills tend to wander.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
I am planning on spotting the hole, that peck depth seems a little aggressive, but okay with me. But 5 mm/min seems really slow to me, it is a lathe so we feed in IPR and my table tells me 5 mm/min is about .00004" per revolution, is that right? ![]() Robert
| 5 was at the slow end before I knew the material. For the AL, being T6 1-3 IPM, but that is only my guess. 3000RPM is slow ![]() Some cutting compound, or kerosene in a spray bottle, will let you get more aggressive. At that depth ratio I go chicken doing it dry. PCB drills are usually carbide, with peck depth same as diameter, or a little less once it gets deeper. Code: (Z0 is touching the face - center drilling already done.) (All inches - we are multilingual :) M3 S3000 M8 (coolant) G83 Z-0.2 R0.1 Q0.03 F3 Z-0.35 Q0.02 F2.5 Z-0.45 Q0.015 F2 G80 M5 M9 M30
| That seems a little more realistic, thanks Neil. If anyone else wants to chime in thats okay too. What I've got seems pretty straight forward, is the .0002 TIR going to sway the result of this?
| Runout will be OK on a 0.75 drill. My smaller drills needs centering checked with a magnifying glass so they don't break.
| 5x dia 1st 3x dia until final depth for pecking Being a Circuit Board Drill, I can't imagine you're going more than 15x dia deep. maximum rpm (or as much as you are comfortable with) f.0013 to f.003 Too slow and the material will clog your flutes. Spot before. |
| How'd you make out? I've drilled a Ø.0040" before RPM is your friend To bad no live tooling you could counter rotate the drill against the spindle and really get the R's up there. Misubishi makes a really good center drill with a minimal flat (about .0005) these work best for starting small drills. Kyocera, in my eyes, leads the industry for circut board drills. Get lots of oil and air down there if the drill starts to bind in the gummy aluminum it'll be over in a hurry. Good luck
__________________ Ryan Kutz, Process Engineering Coordinator, Precision Plus, Inc. Redefining American Manufacturing |
#10
| Everything went fine, 1 drill 50+ parts. RPM is good and I was limited to 3000. Being attentive to chip load. Also I think making sure the holders and run out were/was reasonable helped. Robert
#11
| You just get better at it. Examine the drill tip with x10 magnification and make sure no dull spots. You can resharpen if you really want.!! What better use for worn drills, other to bust a few learning how. How long on the grinding wheel? Sense the temperature rise with your fingers 2mm away from the wheel.!! http://www.cnczone.com/forums/453542-post181.html http://www.cnczone.com/forums/453963-post183.html Then use a diamond lap. If the drill is just dull, a few rubs on the lap and it works again.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 05-03-2011 at 07:11 PM. Reason: typo |
| problems drilling small holes in G10 | kentw | Composites, Exotic Metals etc | 19 | 05-10-2011 02:21 PM |
| DT software-cut height on small holes | Bigrhamr | DynaTorch | 10 | 02-07-2011 09:41 AM |
| Drilling very small holes | William Demuth | CNCzone Club House | 7 | 12-21-2008 03:56 PM |
| Drilling small holes in Die steel | drk | General Metalwork Discussion | 1 | 08-13-2008 01:59 PM |
| Need Help!- Help milling small holes in polycarbonite | Ferny | General Metalwork Discussion | 3 | 04-10-2008 09:05 PM |
