Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 03-30-2011, 03:54 PM
timf is on a distinguished road
dnc from card
i'm trying to understand a star SR-20Rll swiss turn machine.
does anyone know if i can use M198 to DNC from memory card with head 2.
i got it to work with head 1 but get "data not found" error when trying to do the same thing with head 2.
is there special formatting different from head 1 or is it just not possible
Old 04-05-2011, 07:34 PM
petriej is on a distinguished road
As far as I know, you can't stream on Head 2. So if it's a big surfacing program and your using 21-24, then you'll have to turn up the stepover until you can get it into your control. If you are using 31-35 you could M40/M41/M82/M83 and stream everything to Head 1. Can't multi-task, but that's the best I can tell you.
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
Need Help!- SD card MBR The Blight General Electronics Discussion 3 06-26-2009 01:43 PM
Need Help!- xmd sim card spider Cadkey / KeyCreator 0 06-03-2009 06:34 AM
Need Help!- I/O card? arduous Stepper Motors and Drives 0 04-16-2009 04:11 PM
What Card Is This... Cali-V Controller Cards 2 11-28-2007 06:39 PM
LPT card widgitmaster General Electronics Discussion 7 07-07-2005 08:51 AM
