Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 03-28-2011, 12:13 PM
Tornos100 is on a distinguished road
Red face gun drilling
I was wondering if anyone has had any experience with using gundrills on citizen L20's. I with be trying to use a .0225 gundrill to drill a depth of 1.200.
Wondering about high pressure settings, along with feeds and speeds. Any help would be greatly appreciated.
Old 03-31-2011, 06:58 AM
g-code_junkie is on a distinguished road
gun drilling
first drill pilot hole 1.5 to 3xd.
position gundrill inside pilot hole before turning on hp coolant.
may have to start spindle after in pilot.
when done return to starting depth in pilot hole.
turn off hp then exit.
not knowing the material sfm130/230 .0002/.0008 ipr.
hp-1500 psi min.
5 micron or less for filter.
Good luck
Gun Drilling 316 yoopertool Metal Working Tooling 4 08-16-2011 10:11 AM
Need Help!- Drilling 303 SS Gerdy General Material Machining Solutions 5 02-14-2011 07:07 AM
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
1mm or 0-80 drilling in al star1280 General Metalwork Discussion 10 12-18-2007 10:07 PM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
