Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 03-15-2011, 03:30 PM
barryjames is on a distinguished road
iemca ch112 problems
have iemca ch112 barfeed and every time bar end returns barfeed stops just before bar drops into channel can anyone help
Old 03-16-2011, 07:22 AM
MikeMc's Avatar
MikeMc is on a distinguished road
I am not sure what you mean by just stops. DOes the bar feed shut off? Does the servo motor stop spinning?
www.atmswiss.com
Old 03-16-2011, 04:31 PM
the bar end returns then drops bar end then just before channel opens then barfeed stops loading cycle and after timing out red light flashes on bar feed
when winding manually everything mechanically is free .dont know if a sensor is playing up or not
Old 03-18-2011, 07:07 AM
g-code_junkie is on a distinguished road
ch112
first zero return the loader and then check the switches or prox sensors .
good luck
Old 03-19-2011, 07:34 AM
VSO VSO is offline
VSO is on a distinguished road
i guess it is just because of the sensor does not detect the bar end. check out the tightness of the clamps. a faulty clamping sensor is possible, too.
Hanwah ML12 & Iemca Genius 112??? MX1 CNC Swiss Screw Machines 4 12-23-2011 03:08 PM
Iemca Bundleloader Refurb Project abhthree General Metal Working Machines 0 10-19-2010 09:11 PM
Need Help!- Bent bar stock jams Iemca barfeeders on Star Swiss Machines pneumadyne CNC Swiss Screw Machines 9 04-15-2010 05:17 PM
CNC Problems WCHScarpentry General CNC (Mill and Lathe) Control Software (NC) 4 02-26-2010 01:20 PM
G64 Problems. ckirchen Mach Software (ArtSoft software) 4 06-29-2005 10:15 AM
