Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 02-25-2011, 12:38 PM
DCogswell is on a distinguished road
DCMT 21.51 insert dims
Anyone know where to find the complete dimensions of a DCMT 21.51 insert?
I've got some coolant thru Micro 100 holders and they spec out that insert. However, when I'm trying to order some inserts from another mfg, they don't know what size the 21.51 is.....
Old 02-25-2011, 01:06 PM
g-code_junkie is on a distinguished road
dcmt 21.51
Mitsubishi,ceratip and ntk inserts come in those sizes
goodluck
Old 02-26-2011, 01:38 AM
hacdlux is on a distinguished road
1/4 ic
3/32 thick
1/64 tnr
http://www.ccpa.org/pdf/B212_4.pdf
Old 03-06-2011, 07:37 AM
PixMan is on a distinguished road
Very common insert size, any worthwhile maker would have it. Some European and.or Asian makers might not show it in it's ANSI designation, but rather tin the ISO designation of DCMT (or DCGT) 070204.
If you tell me what material you are cutting, the surface finish you need to get (please don't say "as nice as possible", give an Ra value), and the cutting speeds you think you can achieve and I can recommend some inserts to try.
Carbide inserts DCMT 090204 etc Controller CNC Tooling 8 05-26-2011 10:51 PM
Need Help!- Ballscrew Dims for X-3 Conversion Joe_Public Benchtop Machines 0 10-17-2010 10:26 AM
Chart of insert types? (DCMT, CCMT, VNMG, etc) cnczoner General Metalwork Discussion 4 03-09-2008 07:40 PM
I Need a Yoke (and/or dims) for a Bridgeport mxtras Bridgeport and Hardinge Mills 24 03-20-2006 02:35 PM
