| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hi, I set-up and run an enc 162. I have an alarm code #2018 which reads "motor fault/ spindle variator". I contacted Tornos U.S. and was told they needed the code from the digital readout in the electrical panel in back. It read "AL- 02". I was told that my rpm's were to high for material being turned. I dropped my rpms from 3000 to 1800. it ran fine for about 8 hours. Got the same alarm code, but the electrical panel digital readout is now "AL- 06". Can anyone tell me what the AL - 06 means? I reset the machine again and the alarm went off again without the machine even running. Any and all help is appreciated. Thanks |
The alarm 2018 is indicating there is a fault with the spindle motor or the drive. Check the spindle/motor is not jammed. The alarm AL-06 is coming from the spindle motor drive, it's an over speed alarm, it says that the motor speed exceeds 115%. However if the alarm is coming without the motor even running, when you power on, it's very likely you have a fault with the spindle motor drive. If that is the case it will need replacment or repair. You need to contact Tornos US for advice.
__________________ www.tornos.com THINK PARTS - THINK TORNOS |
I had the same thing happen to my machine. You need to contact Fanuc. Don't bother with Tornos. Roland is good, but even he sent me to Fanuc. I had all the same alarm codes and ended up replacing the spindle control panel in the back of the machine. Here is a link for the alarm codes - Fanuc Alpha axis and spindle alarm codes Be advised, the panel wasn't cheap. |
Haha |
| Need Help!- Programing Tornos ENC 167 , 163 | dali_290 | CNC Swiss Screw Machines | 0 | 11-12-2010 04:44 PM |
| Tornos ENC HELP!! | EvansMachine | CNC Swiss Screw Machines | 1 | 04-21-2010 11:12 PM |
| TORNOS BECHLER M7 | CHANDRU | CNC Swiss Screw Machines | 1 | 06-21-2009 08:17 AM |
| Need Help!- Tornos - Bechler ENC 162 | Paavan Rastogi | CNC Swiss Screw Machines | 6 | 01-07-2009 09:06 PM |
| Tornos Enc-264 programing help | EvansMachine | CNC Swiss Screw Machines | 0 | 05-12-2008 12:26 PM |
