Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 01-07-2011, 07:20 AM
brianpnh is on a distinguished road
any ideas tsugami mu38sy
I was wondering if anyone here has a good method for indicating main side drills on the mu38sy. anymethod besides the old cut and measure method. the problem i run into is finding an indicator that has clearance to do full rotation around a drill for full indication.
any suggestions would be greatly appreciated
Old 01-10-2011, 12:07 PM
JMS4287 is on a distinguished road
Mini Probe
I'm not sure about that machine.. But I got a Solartron Metrology "Mini Probe" a few years back, for indicating tools in tight areas on other screw machines. Mainly where length is a problem. I can ussually get into places that I can't fit a standard indicator...I stole a dovetail from a test indicator, and bolted it to it, so I can use standard swivel indicator holder, and then stick it in a guide bushing...works great for tramming in drilling staion on most gang blocks...I don't recall the cost, but I know the setup ending up being expensive...the only down fall is the wire getting in the way...but that's not that big of a deal.
Solartron Metrology - Specialist probe - Mini Probes and Lever Probes
Old 02-14-2011, 02:16 AM
DCogswell is on a distinguished road
Put a gage pin in each, the GB & the tool holder.
For example: .500 pin in tool holder, 1.0" pin in GB
Index tool above GB in the X axis. Then jog tool in the X axis until the 2 pins touch, then goto offset page and select the tool/offset you are dialing in, type "X1.5" then press the softkey "measure".
Do the same for Y axis but, I don't remember if the "measure" feature is available for that offset page. You may have to do it by calculating the positions.
Call REM Sales (Rem Sales) and ask for applications, I'm sure they'll be of some help.
Thoughts on Tsugami timan CNC Swiss Screw Machines 25 10-23-2011 11:29 AM
Need Help!- tsugami S25(D) lukajt CNC Swiss Screw Machines 0 09-21-2009 09:05 AM
Tsugami PL3B Help Kevin Taylor CNC Swiss Screw Machines 1 09-05-2009 09:10 PM
Newbie- Tsugami T-SPD rmcclane Want To Buy...Need help! 1 10-25-2008 02:20 PM
Tsugami TA3 Manual hien100881 General CNC (Mill and Lathe) Control Software (NC) 0 06-21-2006 08:55 AM
