| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hi Everybody. We are getting our first Swiss Machine next month and are about to purchase cutting oil. Is there a giant difference between Mineral Oil and vegetable oil. Tool life, surface finish, mist, smoke, material limitations.... Any thoughts from the zone would be appreciated. |
| I have used both and they work very well. The biggest issue I had was when using 2000PSI hi-pressure coolant pump. The mineral oil does not recover as fast as the Veg. does. This is only a problem when the cycle is so fast that the oil gets worse as every part is cut. Also $$$$ |
| Thanks for the reply. Luckily we aren't using a hi-pressure pump. I am mostly concerned with tool life. I have called several cutting oil manufacturers and can't seem to get a straight answer which leads me to believe that any difference in tool life is negligible. |
| I was using vascomill 22 in a Hardinge CNC, and it worked well, mostly. The thing I worried about was the contamination of that oil by the waylube, which was vactra2. eventually, I knew there was too much waylube and had to drain/clean, reload. The vascomill lasted about a year before I felt it was no good anymore) |
| vm-1 versus newer vm10 converational versus g code | powerstream | HURCO | 6 | 07-13-2010 02:35 AM |
| Mineral Micro/Macrophotography Stand | Micromount | Hobby Discussion | 4 | 02-24-2009 11:37 AM |
| Ease of use.. GibbsCAM versus Mastercam versus BobCADCAM, etc.? | squale | General CAM Discussion | 4 | 11-10-2008 04:41 PM |
| mineral cuting oil or water soluables for cnc? | pizzaman | CNCzone Club House | 0 | 11-25-2007 05:42 PM |
| Mister versus flood versus ??? coolant system | split63 | Bridgeport and Hardinge Mills | 14 | 10-02-2006 05:18 AM |
