| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Is there any coding that will allow me to mill from the top of the part with normal G2/G3 non-diameter coding? We use Mastercam for our mill operations out here and do all our Swiss programming manually. For 99% of our parts that works great, but we have a handful of parts that we need to do some top mill work with interpolation. This gets to be a PITA when it comes to setting up the G2/G3's correctly. My other option is to get a post processor for Mastercam written to spit the code out properly but I'm hesitant to do so until I'm sure there's no other option (other than manually doing all the converting). |
| G12.1 (Milling Interpolation) is usually used to compensate for an axis you do not have but when in this mode ALL commands are radial even "X". Try this for your application. G13.1 cancels G12.1 Everything in between those must be radial. |
| Yes, you will use G12.1, right after use a G19 to change your plane from X-Z to Y-Z . G16- Plane select y-Z Cylindrical machining. G17- Plane select X-Y G18- Plane select X-Z normally used. G18 is when power on. G19- Plane select Y-Z This should work. |
| VDI gang tools: Anyone using them? Why are they so difficult to find? | MadMax | General Metal Working Machines | 0 | 10-06-2009 10:13 PM |
| New Free tools for pcb milling | kn6za | General Electronics Discussion | 11 | 04-23-2007 10:48 AM |
| Insert Milling Tools? | Joseph Souza | General Metalwork Discussion | 11 | 10-18-2006 08:26 PM |
| gang milling | Thoob | General Metalwork Discussion | 2 | 09-04-2005 08:40 PM |
| thread milling tools | rrrrrgh | General Metalwork Discussion | 2 | 08-27-2005 07:16 AM |
