| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
i have an upcoming job in 4340-m i am having problems tracking down cold drawn or ground stock one supplier has the stock in hot rolled and turned condition but i've never ran this before and am woried about it jamming in the gb stock dia .750 and ive got +-.002 tolerances on this side of the part machine is a tsugami ss32 with a std- td32 guide bushing all else fails i'll send the bar out for grinding and run it that way |
| It is going to depend on the OD tolerance of the bar itself, if it is too far off it will stick in the GB. The other concerns will be the straightness of the bars and out-of-round conditions. You could have the vendor send you a sample bar to check, or just have it ground.
__________________ www.atmswiss.com |
| Don't get the hot rolled. The scale on the bar sucks! The turned stock is not all that bad. I have done many jobs with turned stock. Just make sure the bars are the same all the way down and not bent to bad. Also depending on your guide bushing it may not like the bar if its on the high side of the turned tolerance. If you are getting a bar or two, turned should get you by. If this is a major production or a tight tolerance part you should get it ground. Nice mahine you there |
We actually managed to find ground bar from another supplier(not very consistent) i just pulled that job off the machine this morning. the ss32 is not convertible (guide bushing only) the second part in the group has a 1/4 broach and it spiked the load meter on my z2 axis t0 180% so i am going to put the second part on my mori thanks everybody for the replies |
| i was wobble broaching, i'm fine with doing it as a secondary were having problems with the boring bar before the broach and it gives us a chance to inspect the parts before we broach them the 2 point intrigues me. i take it that it would be a straight punch with indexing the c axis, still not sure if it would reduce the thrust low enough, it is a 12 pt broach going to have to look into it there is no chucker kit for the 32mm machine, only the 20 mm. they do make the ss32l which is chucker only( they came out with that about 6 months after i bought mine) |
| Need A Quote- Hex Bar Stock turned and drilled/tapped | ez3022 | Employment Opportunity | 4 | 09-30-2010 06:04 PM |
| Guide bushing scratching on 303.... | PoiToi | CNC Swiss Screw Machines | 4 | 02-28-2009 01:20 AM |
| Rough Cut Stock Material - QUIETLY! | tikka308 | Benchtop Machines | 37 | 07-24-2008 11:14 PM |
| Pneuamtic Guide Bushing Assm on Citizen's | JMS4287 | General Metal Working Machines | 1 | 08-29-2007 07:45 AM |
| Noob question about rough stock dimesions | rlrhett | General CNC (Mill and Lathe) Control Software (NC) | 1 | 02-16-2007 05:16 PM |
