Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 11-16-2010, 08:12 PM
danrudolph is on a distinguished road
Habegger Guide Bushes with Carbide Rollers
Has anyone used these guide bushings?
Our products
We are looking at putting one of these in a fixed GB R-series Citizen machine. The machine would be setup for 0.125" Ti and that's it. We are hoping that this will be very precise and allow Ti to run in a fixed GB machine with high RPM spindle.
Any experience would be helpful!
Old 11-17-2010, 02:49 AM
Deco-Doctor's Avatar
Deco-Doctor is on a distinguished road
Hi
We use these Habegger roller guide bushes extensively for machining titanium medical parts. They produce very good results and can be run at high speed. One big advantage is that they virtually eliminate the problem of the titanium bar stock jamming in the guide bush as the sliding friction is very low.
You must provide the bush with a constant flow of clean filtered cutting oil to prevent the cutting chips from contaminating the rollers. We use a 20um paper filter element.
www.tornos.com
THINK PARTS - THINK TORNOS
Old 11-17-2010, 11:24 AM
ProProcess is on a distinguished road
Originally Posted by Deco-Doctor View Post
We use these Habegger roller guide bushes extensively for machining titanium medical parts. ....
How much variation in bar size is acceptable for the unit?
thanks
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 11-17-2010, 02:02 PM
thanks
It will be dependant on bar size and material, but these bushes will tolerate a slightly bigger size deviation than a conventional carbide lined bush. They can be run much tighter than a conventional bush without the risk of jamming on high spots.
You would need to consult the manufacturer for exact bar size guidelines.
www.tornos.com
Old 11-17-2010, 03:17 PM
Need Help!- Having trouble boring Parallel bushes for Z axis on my router project DMBGO DIY-CNC Router Table Machines 15 03-17-2012 07:27 PM
Carbide VS Steel guide bush EvansMachine CNC Swiss Screw Machines 8 12-07-2008 09:25 PM
Need Help!- Habegger CNC 80 BACKUP Aiman Ebraheem General Metal Working Machines 6 03-13-2008 02:18 PM
Vesconite for acme nut / bushes andy_ck87028 Mechanical Calculations/Engineering Design 1 03-27-2006 09:34 PM
Help!! - bushes, rods andy_ck87028 Mechanical Calculations/Engineering Design 8 05-20-2005 03:18 AM
