| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
I am attempting to interpolate a simple diameter using axial live tool T1300 in a L720 Vlll. The diameter is off center(X.482) and a .102 diameter hole. For some reason it refuses to mill in a circle, I've milled every possible shape except a circle. Please tell me this is possible without using G12.1. If so does someone have sample code for such a thing. Thanks |
Maybe not the answer your looking for, but use the example in the manual to get you started. too, make sure that your tool pattern is set appropriately and that you've set the Tool Nose Radius values and quadrant. If that fails, post your code here. Good luck.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
One reason is that you run out of Y axis stroke for some operations.
| Need Help!- XYZ Interpolation | jweaverlingtpa | General Metalwork Discussion | 2 | 05-17-2010 08:06 AM |
| How to difine milling interpolation on Citizen C16 | Koalas | Mazak, Mitsubishi, Mazatrol | 1 | 10-08-2009 01:31 PM |
| Need Help!- Polar interpolation on 10T | guhl | Fanuc | 7 | 05-18-2009 06:26 AM |
| vr-11 A & B interpolation | tarponicus | Haas Mills | 1 | 11-05-2008 03:48 PM |
| interpolation | rimcanyon | General Electronics Discussion | 9 | 04-08-2004 01:10 AM |
