Results 1 to 6 of 6
Thread: Tool Life Management I on A220
    Apr 2009
    Is anyone using Tool Life Management I on a Citizen A220?
    We called Citizen NJ and they were stumped why our used count is not incrementing after each cycle. Apparently no one uses it so it never came up or they just don't know what is wrong with our machine.
    Any idea why our used count might not be incrementing? We tried everything, nothing seems to get it to work. It is a standard option as per the the brochure...
    Jan 2005
    Did you look at the instructions in the Operation Manual? Page 6-116. This gives the settings you need for it to work. You may need to be in continous cycle to have it work.
    Apr 2009
    cogsman1,
    yes, continuous does not increment the used count either. i was wondering if there was an m code that might turn it on at the beginning of a program or something along those lines? i read the operation manual and spoke to the citizen folks. last i heard they were contacting fanuc to see why it's not working.
    i am curious however if anyone is using it and it is working for them.
    Jun 2006
    I know that some machines with Fanuc use an M20 as the part counter increment.
    Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
    Jun 2010
    compose page
    you can try going to the compose page ,under maintainence, turn off tool life 1 and tool life 2 then power down.Then power up, turn them both back on and then power down again.When you power back up it should work.
    good luck
    Apr 2009
    strange... last night we got a tool life alarm out of nowhere. i had the life set to 5000 pieces, so about 5000 parts ago it started working. i had it set for about a month or two, when i started this thread.
    all the tools i am using seem to work except T32, which is also odd.
    i'll try to dive into that problem on my own...
    1. Need Help!- management of tool life
      By hongjianming in forum CNC Swiss Screw Machines
      Last Post: 07-28-2010, 12:41 PM
    2. Tool Life Management
      By marko440 in forum Fanuc
      Last Post: 04-07-2010, 04:47 PM
    3. Renishaw tool offset / break probe and tool life management
      By mcash3000 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-20-2010, 10:14 PM
    4. Tool Life Management
      By Jake E. in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-05-2009, 02:13 PM
    5. Need A Quote- tool life management
      By oskar the 2 in forum CNCzone Club House
      Last Post: 05-19-2008, 09:51 PM
