Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 07-30-2010, 02:34 PM
stevehering is on a distinguished road
Need to pull out y1 ballscrew on citizen L-20
I have a citizen L-20 5MZ and im having a hell of a time getting to my y1 axis ballscrew! Anyone know how to go about taking the covers off so I can pull out the whole ballscrew?
Old 07-30-2010, 03:49 PM
ProProcess is on a distinguished road
STOP!!
This is by no means a snide remark and I mean you no disrespect, but...
if you are having trouble figuring out ho to take the covers off, I would no recommend that you not proceed with the ballscrew removal.
Call your local Citizen Dealer as they should be involved with this type of repair.
Good luck.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 07-30-2010, 04:42 PM
I thank u for your lack of confidence and your remarks get me no closer to the ballscrew.
Old 07-30-2010, 08:12 PM
Again, I did not mean to offend, I apologize if I did.
Where are you located?
Did you try your Citizen dealer?
I thought that would get you closer as they could walk you through just about anything.
There is nothing trick or secret about the covers coming off to get to your screw.
Go to town with you metric allen wrech set till you get to what you need.
All the screws are in plain sight, start by taking the top cover, side cover over the Y1 motor and two-piece back cover off.
After that, see what still in your way and remove those items.
It's been a while since I've done and do not remeber 100% what needs to be removed, plus I'm not near a machine at this time.
The job is doable.
Take your time and use common sense.
If you're not sure, then stop and ask more specific questions here, people(myseld included) will try to help you.
Good luck and let us know how you make out and if we can help.
Old 07-31-2010, 11:22 AM
its not nescessarily the slides and covers giving me fits. The tool post is the major hassel which i have removed and am working on getting the saddle out of my way. Before that i have to remove the ball screw (i believe) need to look more into it. And of course the books just show u enought to get yourself in trouble.
Old 08-03-2010, 02:57 AM
dookie2022 is on a distinguished road
Why are you removing saddles / tool posts as you should get access to the motor and coupling to the ball screw and motor / undo coupling / remove motor / remove bearing motor housing if nessecary then access ball screw mounting cap screws remove ballscrew and mount new ball screw attach coupling to motor and reset zero home position that is a general proceedure for any ballscrew
Old 08-06-2010, 05:46 AM
The reason is that my machine was alarming out. The tool post was in such a position that wouldnt allow me to get to a few bolts holding the slide cover in place. But it is all done and up and running once again!
Need Help!- Bar Pull Delays bmlw Daewoo/Doosan 4 02-14-2010 08:07 AM
Need Help!- Bar Pull on Fanuc 15T bmlw Fanuc 12 02-01-2010 11:29 PM
Need Help!- need a bar pull program!! the mill kid Mazak, Mitsubishi, Mazatrol 1 08-13-2009 05:22 PM
Need Help!- BAR PULL? travis1 Haas Lathes 10 02-11-2009 02:22 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
