Haven't played with the tool life management in a while, but if I remebember correctly it's picking up on the tool offset # not the location, so why not just use a differant offset # if the tooling changes. You can use a macro to tell the the program what tool you have in the machine, and have the program select what offset # to use depending on what tool your using.
LinkBack URL
About LinkBacks
