Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 07-17-2010, 08:14 AM
chet470 is on a distinguished road
Citizen Question
For the Citizen experts. Is there a way to incorporate the cutoff process and start position process directly into the program rather than having to do it manually?
What macros does it read for the cutoff, and for the move to start position? These questions are for a L20 M7 and M8
Thanks in advance
Brett
Old 07-17-2010, 08:43 AM
cogsman1 is on a distinguished road
Yes there is a way.
Load the attached file into the machine and call it as a SUB program at the beginning of $1. MAKE $2 WAIT UNTIL IT IS COMPLETED.
$1 ................................. $2
M98P322
!2L322 ........................ !1L322
This is for the L7-20. There is NO M7 or M8 machine.
You need to call the cutoff tool into position and position the stock FIRST!!
File Type: txt 322.TXT‎ (445 Bytes, 84 views)
Old 07-17-2010, 09:19 AM
Thanks for the reply. I new to citizens and was referring to the model # on the manuals, it says 5m7 or 5m8 which is where i got the m7 m8 from. Anyway thanks for the information. And what excatly is program 322?
If i have to position the cutoff tool first would something like this work
$1.................................................................$2
IF[#5041LT0]GOTO500......................................!L322
T0100
G0X[#814+.05]
M98P322
N500
!L322
Old 07-17-2010, 09:23 AM
My goal in this scenario is to put a safety check in place in case guys forget to move to start position which seems to happen regulary.
Old 07-17-2010, 09:26 AM
OH
Didnt see the attached file! Thank you!!
Old 07-18-2010, 08:04 AM
This program will got into alarm if the cutoff tool is not in position. The screen will read "Call Cutoff".
If you do a tool call as you show it will add cycle time on EVERY cycle.
FYI,
5m7 = L5-20 (5th Generation L20), Type VII
5m8 = L5-20 (5th Generation L20), Type VIII (Added capibility, Gangblock)
See the attached file for a line-by-line explanation of what will be done by that program.
"Train the operators, but first protect the equipment!"
Old 08-05-2010, 07:00 PM
kwmkoester is on a distinguished road
The M stands for Mitsubishi, F stands for Fanuc
FYI,
Just to expand on your breakdown, M is for Mits, F is for Fanuc
Old 10-28-2010, 01:19 PM
jessebpm is on a distinguished road
I am trying to use this on my L6-32 but i am having trouble with the G53 -#818. It wants to go to minus what is in my mc data from machine zero. It is not going to the start position.
Old 10-29-2010, 06:03 AM
For that machine change that one line to be
G53Z#872-#818
The system settings are different between some models.
Old 10-29-2010, 07:30 AM
thank you. I am trying to learn how all this stuff works. Kinda got thrown to the wolves with the swiss machines. Learning as i go though..
  #11   Ban this user!
Old 10-30-2010, 12:46 PM
I am still having problems with this on the L6-32. I changed the g53 line to #872-#818. The first time I ran the program it worked just like it should, went right to start position after cutoff. Now every time after that It wants to go forward toward the guide bushing and alarms out.
  #12   Ban this user!
Old 11-01-2010, 12:22 PM
ProProcess is on a distinguished road
what alarm?
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Need Help!- Citizen L25 JOlalde CNC Swiss Screw Machines 2 06-12-2010 06:09 PM
Need Help!- Citizen M32 shrektaylor CNC Swiss Screw Machines 3 05-28-2010 06:04 AM
Need Help!- Citizen L20 Tornos100 CNC Swiss Screw Machines 1 04-24-2010 12:52 AM
Citizen M series basket and counter Question EdgeCrusher CNC Swiss Screw Machines 3 12-16-2009 05:44 PM
Need Help!- Citizen L25 appusivadas CNC Swiss Screw Machines 4 07-16-2009 08:51 AM
